Wink howd you find yours from the group buy you bought? I remeber you posted a pic somewhere, but cant remember now..
In the pics, it doesnt look like the lights have any distance??
Can you take a shot of them, from behind the lights?? So i can see how far the distance is.
Cheers
Some bulbs (eg H4) are used both as high beam and low beam.
Therefore H4 HID kits can also be used both as high and low beam - that is why they are usually more expensive than dedicated low beam HID kits.
I wouldn't have a problem buying the ones from that group buy.
Mid range there is the BJ Union ones which my brother has fitted on his Lancer - pretty good quality.
Top range are the Phillips and Raybrig ones.
has anyone installed one of BATMBL's kits?? I got the Kaixen (korean) kit off him but haven't put them in yet and when i looked the installation booklet, it wasn't very detailed.... plus the idea of having to take the front bumper off... >_<:D
so yeah, anyone done one of BATMBL's kits? otherwise... i might have to find time one day and make a DIY thread about it cos i'm sure other ppl have bought the same kit off him
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
