  • Replies 65
yeh i had a drive in one they go alright once you hit vtecbut yeh nothing compared to the gtst.....all my mates are obcessed with integras but yeh they arnt that good. they are pritty good for a economical car that still goes alright
I find the integra runs well on the twisties. Not a drag car.
Jon
ahh k yeh the vtirs do handle nicely, only reason i bought it up is ive looked at alot of ppls posts and no one really talks about them and im not sure why. yeh theyr arnt really good for dragging but they are good economically and love the high revs as well!
A GTS-t has a turbo. It takes relatively little effort to dial in more power, compared to a Honda NA engine. Do non GT-R Skylines have "street credential"?
And the reason why no-one talks about them here could possibly be because this isn't a Honda forum. We don't talk about 1920's Packards, De Loreans nor Ascari KZ1's here either.
If there is a vs thread, everyone would tend to go for the top-spec Type-R instead of the silver medalist.
yeh i think they will be better on petrol....would it go as hard as the gtst or not? which one would u prefer?
If you already knew, then why did you ask?
And you're asking on a Skyline forum whether people would prefer a GTS-t over a Honda? Were you expecting an fair and balanced response?
Like scathing said this is the last place people will be raving about hondas if you want more info should check out hondas forums. Also you cant compare a NA against a turbo, cause turbo owns hands down simple. If you want an NA car thats quick, rev high and economical go for the vtir. But if you want something faster and very keen to modify it further to gain more hp then get the gtst. Beacause there are limitation to hondas as they will cost heaps to produce more power (eg turbo charging it).
Edited by JUNR34
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
