i think a good brand ebc like avcr ect... are really good with holding boost levels, and i know avcr you can change your boost levels threw out the rev rand and per gear. but theres a differance 5-600 dollars compared to 20. :laugh:
me i just have a bleed valve :thanks:
i got a blitz ebc type s, its not 2 bad, spikes a bit but thats cos i think it wasnt set up right..gota get dyno tune soon with a service....
i also found out it has a neat little feature that increases boost depending on acceleration speed...if ur going hard it puts it high, but if ur cruising it turns it down....not sure how it works though.
Just a quick plug for myself, Ive got a spec s for sale, used but good condition, send me a PM if you are interested.
I have used both.
I statred with a bleed valve (still have it if you want to buy it) and then went to the EBC.
The BV got me started, and was great value for money, buyt the EBC brings boost on earlier and harder (though I could soften it if needed) and holds boost MUCH better. (less concern about hot days and cold night boost increases). If you have the cash I prefer the "Do it right the first time" approach, but a BV will give you a lot of bang for a few bucks.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
