Just stripping a halfcut we bought for parts to repair accident damage.
I'm also keeping the motor, for now anyway but there are plenty of bits left over.
All parts are standard 1992 R32 GTS25 but many are the same as the R32 GTSt
Both front struts $40 pr
Rear struts (springs and shocks, no top mount) $30pr
Front hubs (4stud) complete with upper and lower control arms and tension rods $85 a side
Brake calipers (single piston) and rotors (4stud) $80 the lot
Alternator (looks so new it must be a recent replacement) $80
Power steer pump 2WS complete with reservoir $50
Front power steering rack with tierod ends $120
Brake booster and master cylinder $65
Clear fog lights $40 pr
Starter motor $40
Exhaust manifold (non turbo) with heatshield $20
Wiper motor $25
Speedo cable (auto) $25
Airbox with piping to throttlebody SOLD
Throttlebody with TPS $50
Radiator overflow bottle $15
Stereo brackets and din pocket wth flip up lid complete with free original cassette deck SOLD
Dash center console (body) $20
Center console trim (stereo and gear stick surround) SOLD
Glovebox lid $20
Dash panel above driver's knee with fuse cover $15
Footwell side panels $10 ea.
Auto shifter assembly $20
Rb25de ECU (auto) $50
Auto Transmission (5speed) complete with torque converter and tailshaft yoke $100
There is also a myriad of modules, relays, plugs etc
Just ask and i'll see if I can find it for you.
Further parts from 1989 R32 GTSt
Motorised front spoiler lip $40
Std intercooler $30
Std catback exhaust (very clean) $50
All parts appear to be in good condition for age and are believed to be working.
https://www.sau.com.au/forums/topic/117452-r32-gts25-halfcut-leftovers/
Hey dude
Stereo brackets and din pocket wth flip up lid complete with free original cassette deck $40
i want i want i want i want
sent you a message
let me know of payment details.
cheers,
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
