StOjA Posted May 12, 2006 Share Posted May 12, 2006 I need help .... i need to know what needs to be done to my car before i put a better turbo on my car. I have a front mount 3 inch turbo back zorst and pod. everything else is stock. im interested in putting a better turbo, also i need to know what turbo to get i dont want to spend big bux and dont want huge power. i know of a few people putting highflowed 33 or 34 turbos on there r32's. are these reasonable turbos i should look for. What i am looking for is a little bit more power but most of all relyability. thanks for your help sorry i dont know much .. Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/ Share on other sites More sharing options...
ToF Posted May 12, 2006 Share Posted May 12, 2006 You should probably look into the fuel supply before going further. ie. Fuel pump, injecters, possible ECU remap. Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2160840 Share on other sites More sharing options...
R31Nismoid Posted May 12, 2006 Share Posted May 12, 2006 http://www.skylinesaustralia.com/forums/in...howtopic=103095 http://www.skylinesaustralia.com/forums/in...showtopic=45218 http://www.skylinesaustralia.com/forums/in...showtopic=66556 just a few Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2161423 Share on other sites More sharing options...
WazR32GTSt Posted May 12, 2006 Share Posted May 12, 2006 based on my experience, anything more than the stock turbo requires a fuel pump i can recommend an rb25 turbo and the only extra thing you will need is a fuel pump (as mentioned) and that will work with the stock ecu nicely this will also maintain reliability you might want to also consider a boost controller.. cheers, Warren Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2162140 Share on other sites More sharing options...
StOjA Posted May 15, 2006 Author Share Posted May 15, 2006 thats sounds reasonable enough...... Would you say an R33 turbo would be abetter choice over an R34 turbo... are these things straight bolt ons for the RB20DET Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2167225 Share on other sites More sharing options...
CATKICKER Posted May 15, 2006 Share Posted May 15, 2006 R34 turbo would be better again, but a lot harder to come by and more expensive. If you go and R33 turbo, you want to get it from a series 2 as they have a nylon compressor wheel and are rated at 180-190 odd rwkw. I have an R34 turbo on the way for mine, can't wait! I have a bosch 040 fuel pump and a remapped ECU, I also have 3" dump back, POD filter, EBC and front mount... will get it retuned once I fit my GTR injectors and Z32 AFM. Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2167627 Share on other sites More sharing options...
WazR32GTSt Posted May 15, 2006 Share Posted May 15, 2006 http://www.skylinesaustralia.com/forums/in...opic=115398&hl= this is my experience with te rb25 turbo - hope it helps, stoja Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2168441 Share on other sites More sharing options...
StOjA Posted May 15, 2006 Author Share Posted May 15, 2006 R34 turbo would be better again, but a lot harder to come by and more expensive.If you go and R33 turbo, you want to get it from a series 2 as they have a nylon compressor wheel and are rated at 180-190 odd rwkw. I have an R34 turbo on the way for mine, can't wait! I have a bosch 040 fuel pump and a remapped ECU, I also have 3" dump back, POD filter, EBC and front mount... will get it retuned once I fit my GTR injectors and Z32 AFM. What rw/kw you expecting with that type of set up and if you dont mind me asking what would it roughly cost. Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2168449 Share on other sites More sharing options...
CATKICKER Posted May 15, 2006 Share Posted May 15, 2006 (edited) What rw/kw you expecting with that type of set up and if you dont mind me asking what would it roughly cost. I managed to get mine for $530 shipped... But I have been looking for about 6 months! I am aiming for a very responsive 200rwkw! Should be quite acheveable, just got replace the dump and cat I rekon. Edited May 15, 2006 by CATKICKER Link to comment https://www.sau.com.au/forums/topic/117480-better-turbo-for-r32-gtst/#findComment-2168557 Share on other sites More sharing options...
