cause my dad drove the car...
and his sholders are not very small... anyways crunched it and its cracked like anything...
i ripped it out... and damn it very hard to clean and take out the double side tape...
how did you take yours out?
Take off the rubber mouldings... then remove the entire top trim/bracket with a phillips head screwdriver (total of 6 screws I think)
Turn it around and you will see a few clips holding the weather guard onto the bracket. Remove these carefully so you don't bend the aluminum bracket. Re-mount as required.
To clean the stuff off the actual rubber without using a blade that can damage the trim, I used a substance called Prepsol which is like an alcohol.
What it does is "freeze" the tacky stuff so you can either scrape it off with a credit card or your finger nails. Took me a good few hours to get it clean, but I got there :woot:
