  • Replies 75
Posted Images
mate that stagea has an incredible high front... opted for the navara spec suspension, hey? lol definately lower that id say... let us know how it goes with those big black boots.
I see the fmic - what else have you done to it?
https://www.sau.com.au/forums/topic/117507-new-mags/page/2/#findComment-2168226
ha ha na mate its called the safari spec, that extra clearance comes in handy when traveling those wild jungle tracks or taking the kids camping at fraser.lol. when I had the stockos on people asked me if I had lowered it then I put the mags on and hey presto instant safari spec :woot:
thanks for the nice coments ska....
https://www.sau.com.au/forums/topic/117507-new-mags/page/2/#findComment-2171195
My Stagea sits nose-up too, and I've noticed most of them do (unless modified).
Mine will be the opposite soon, I have to raise the back to allow the camber to be straightened, either that or roll the guards so that the wheels can wear evenly over the whole tyre and not just the inside 5cm or so....
Dont know yet if we "have" to raise the front, but probably going to anyway, just so that it doesnt look ghey.
https://www.sau.com.au/forums/topic/117507-new-mags/page/2/#findComment-2173246
i thought mine sat higher at the front too... but i had a good look on flat ground and i think its just that the front wheel arch sits higher. if you look along the body line along the bottome, it actually angles down towards the front, but the rear wheel is still higher in the arch. Think its just for turning clearance.
but yeah rb30dett your car looks like youve stalled it up to about 5k and then just let loose with a massive launch... its crazy.
https://www.sau.com.au/forums/topic/117507-new-mags/page/2/#findComment-2173630
The reason my car apears to be hight in thr front is cause pics were taken from ground level, car carrys 200kg+ in the back (at time of pics) and those arches are def higher in the front. offset for the wheels is 35 fills gaurds perfect and with all the work gear in the back and 5 up, with stocko suspention have absolutly no clearance issues (au falcon listed mags) hope that helps any future wheels buyers will take a better pic on w/end. cheers..
https://www.sau.com.au/forums/topic/117507-new-mags/page/2/#findComment-2174019
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
