Hi Guys,
Its time for the major :woot:. I have gone through millions of post/threads and i just want to ensure i got everything.
Feel free to add or give suggestions on parts. Also, just an estimate on what you guys think a mechanic would charge to do each item.
I will be doing most of the basic stuff myself, but when it comes to water pumps and timing belts - forget it haha.
'94 R33 GTS-T S1 (RB25DET)
Timing belt
Water pump
Cam Seals
Crank Seal
Belt tensioner Pulley
Idler pulley
Spark Plugs
Diff Oil
Gear Box Oil
Engine Oil
Break Fluid
Power Steering Fluid
Coolant
Coolant flush
Injector Clean
Oil Filter
Fuel Filter
All Belts
Hoses
Fuel Pump
Wheel Allign
Ill also be doing the breaks, and have noted other things with majors. Im just really concerned what needs to go on under the hood.
Anything I forgot?
Cheers,
Steve.
Edited by weSky
https://www.sau.com.au/forums/topic/117535-major-service-time-check-me/
tyre pressures
inspect all boots and bushes, suspension components, steering rack etc for loose bolts / wearing / leaking / play
check for oil leaks
check tyre pressures & tread depth
check brake pad thickness and rotor thickness
air filter
check all lights etc.
if you're changing water pump and sh1t, may as well change thermostat
alot of the stuff you mentioned only needs checking, like i wouldn't bother replacing most of the hoses unless they are showing signs of wearing, i wouldn't bother changing powersteering fluid, i wouldn't do timing belt etc. unless it's been 100,000kms since last done
i'm assuming you're doing a 100,000km service? timing belt/waterpump/oil seals/pully's are all pretty major, but i can see your logic if you're going to do the timing belt, may as well do all the other things you'll have access to while you're at it. If the timing belt has been done less than 100,000kms ago, i wouldn't worry about the above stuff.
I had the timing belt done the other day simply because i dont know the history of my car, and i dont trust the odometer.
Turns out the belt wasnt that badly worn, she had lots of life left in here... but boy did i sleep better last night.
Just do everything while your at it, saves the shit fight of having to come back in 2000km's to do the waterpump if you dont do it now and it farks out on you.
Edited by Mr Italy!
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
