  • 5 weeks later...
The one I purchased has faulty oil and temp gauges so now I am looking at getting a 3rd and final one. Has anyone got one IN PERFECT WORKING ORDER they can sell me?
Please PM me.
Thanks!!
Todd
You're so high maintenance aren't you Todd. Why does everything have to be in WORKING order?
I have a few odometers and a few canon exhausts that you can go check out - drop me an SMS and we'll tee it up.
cheers,
J
i gess $50 if thats what your offering. im not 100% sure if i will sell it. im waiting on a nismo 260km/h dash and i would like to check that that all works first as it seems hard to find one with everything working.
i gess a week or so. im in launni but i am more than willing to come to hobart as im trying to get together some parts down there. if you wanted it sooner that could be aranged.
my cluster has 75900 ish on it and my possible new cluster has 55xxx ish. ill let you know in a day or so.
done... let me know when you have it out and we can hook up!
hey damo... sounds good! very keen! happy to slip you a tenna to send it down via post before then if that works for you...
hey todd
i picked up my nismo dash today and every thing seems to be working on it so you can have mine now.
ill come down to hobart in two weeks so we can meet up.
damo
what pressure does your seem to show on average? mine shows just below 4.
After putting this cluster in it shows 4 on startup, then drops just below... at times it is just above 2 (still normal) but then it will drop down to 0 for a few mins and pop back up (it won't do it all the time, just some of the time!). It drives and runs perfectly no matter what the gauge says and it has only happend since I installed the cluster.
I figured the first step would be to confirm what is happening with the oil pressure before looking for another problem (oil pressure sensor, oil pump) but it would be just as expensive (if not more) for me to buy and install an aftermarket gauge or to take it to a mechanic as it would be for me to replace it with one that is working for sure!
Worst case it keeps happening, I can flog off the other cluster and find the true issue or if it is the cluster (most likely) then it has only cost me $50 odd dollars!
Any advice? Or does everyone agree?
Todd ever single 32 i have had i have found that the standard cluster's have never been that flash for the oil pressure or temp gauges.
If your worried about it i would be hooking up an AM oil pressure gauge to double check.
Better safe then sorry and i have a spare one kicking around if you want to borrow it :/
GMB
Thanks for the offer B but I am not TOO concerned, just something to keep an eye on ATM really. Would be good to know once and for all but I can wait until Damo comes down!
No problemo chief,
normally everything is fine even though the cluster doesn't show that.
But im the sorta bloke that likes to be safe then sorry :D
I've got a NISMO dash if the stock one you get from Damo still doesn't work :D
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
