Hi steve,
Do you have any in stock for a R34 GTT semi-auto? and i've read before that these don't have the trans-oil cooling, has that changed or will I still need the external transcooling kit? how much would it be for both to Brisbane?
Thanks
Dylan.
  • Replies 68
Hi Dylan, you would still need to run a seperate transmission cooler on your Automatic ER34.
The cost of the transmission cooler depends on which core size you select - Please have a look at our website using the URL below and let me know which size you would prefer then I will provide you with a total cost.
http://www.justjap.com/parts_ncooling.htm
Cheers,
Steve
Ok, thanks Steve, only one problem there's not much room left? with the radiator, air-con, intercooler and engine-oil cooler where can I fit the trans cooler?? Or is there one that could combine engine and trans cooling?? dunno help needed?
Thanks
Dylan.
Dylan, what you think is your engine oil cooler is actually your trans oil cooler (unless you took the trans oil cooler off and put an engine oil cooler in its place). I bought a JustJap radiator and put in a Davies Craig trans cooler where the oem oil cooler was. Then I put a JustJap engine oil cooler in the passenger side between the wheel and the bumper bar. I am actually thinking of putting the stock trans oil cooler back in to add to the trans oil cooling since I have actually reduced the volume of trans oil due to removing the radiator cooling section from the system. I plan to put the oem trans oil cooler in series, in the drivers side between the wheel and the bumper bar. I have some pics of the install if you are interested. It is a fairly easy job in terms of technical ability, but you need an amazing amount of different tools and pretty much a whole day to do it.
I did radiator, trans cooler, engine oil cooler and changed turbo in one very busy weekend.
Sweet Nightcrawler, yeh I nearly understood most of that, um i think :) ! Would love to see your pics to help me out, haven't played round with cars for a few years so just starting out again with my new hottie, and like any good woman she's already costing me heaps!
So did you manage to fit the 16" fan on? cause I couldn't on the standard rad without being bodgy and lifting it out over the tank at the bottom. I went twin 12's but since I have to get a new rad, i may aswell try to change this at the same time.
EDITED
Well I've ordered the justjap radiator, and you were spot on nightcrawler it is an oe trans cooler, so if i just change the rad and keep the original cooler will that be ok for a while until i can upgrade to a bigger oil cooler?
or steve maybe you could point me in the right direction too?
Thanks heaps for the advice
Dylan.
Edited by Dylby77
Thanks for all the orders guys - We have plenty more in stock ready for immediate pickup and delivery.
Cheers,
Steve
Just letting you know I received my new rad from JustJap yesterday!
Only ordered it on the weekend and received it on Tuesday, nice service Steve!
So I'm putting twin 12" thermos on (because I had them, but I still think the 16" would be hard to fit)
I still need some advice on the trans-cooling, what size should I go now that I've lost the radiator capacity. something that would fit in the oem place.
Cheers
Dyl.
Hi Dylan, please give one of my staff a ring in store if you still need assistance with the transmission cooler and one of my staff will be happy to work out a suitable solution for you :thumbsup:
Cheers,
Steve
  • 2 months later...
More R33 GTR & GTS-T stock has now arrived - Thanks to those customers who have been waiting patiently :D
Cheers,
Steve
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
