when i shake the rear of the car from left to right i get a clunk i got under the bottom of the car and shook the drive shafts from left to right there was a little play is this normal? if not how do i tighten them up?
the noise MAY also be coming from the hicas when i was under the car i got some one to shake it for me while i had my hand on the steering arms is there a way to tighten up the play in the hicas ?? if its not the drive shafts.
any help would be good cheers dave
https://www.sau.com.au/forums/topic/117608-noise-from-the-rear/
Why don't you get under there and get some one to rock the car! Would be a lot more affective than hoping someone on here has a miricle cure.
If it is an audible knock that you can hear while rocking the car it should be a piece of cake to hear when you're right under there with it!
Ouch, that's a bit nasty! My appologies. I was flicking between threads and e-mail and lost track of what I was doing. No need to go insulting people though, even if i didn't pass year two!
For some decent advice though, your best bet is to get under the car and get a second party to rock the car AGAIN and listen to where exactly it's coming from. Then if you can source a car stathoscope or I'd highly recomend you buy one (only $20approx.) as you'll find it forever useful, pin point exactly where the noise is coming from!
As by checking things willy nilly it will be a long process to fix due to the multitude of things capable of clunking in the rear end. From something as major as subframe bushes to something as minor as a handbrake cable touching the fuel tank!
Oh and just for the record, "Whell", as in your post doesn't have an "H" in it.
yes..
you have to have it jacked up to chech those ball joints/tie rod ends.. just try and rock the wheel from side to side.(as if your trying to move the rack in and out)
but mine a rooted and there not noisy :
you never know its probably just the exhaust hitting on something :P
for a suspension member to be making noise its gotta be heaps farked..so it should stick out fairly obviously...
stathoscope lol you mean stethascope dont you champ
You just can't help but make a fool of yourself! Before I failed year two, I was given a dictionary. Maybe you should invest in one before you bag people!
Stethoscope, noun. Instrument for listening to action of heart, lungs etc. Stethoscopic is the adjective!
English leason over!
I wish you good luck and bid you fair well. It's been very educational.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
