Hello,
I have had my R32 GT-R STOLEN!!! I just got it not even complied yet help!!!!!!!!
I just put it up for sale on the forum because I couln't afford it anymore details are:
17" Advan Model 6 Wheels With Dunlop Lemans Rubber.
Twin Apexi BOV's.
Nismo Gear Shifter.
Twin Apexi S/Steel Pod Filters.
A/M Clutch (replaced 3000kms ago) Chassis number:BNR32012724
Timing Chain replaced at 112,000kms
Bosh Remote Oil Filter System
Just had engine flush and Oil changed to Castrol Formula R Synthetic 5w-30.
Ground Wire Kit.
Just had Brake Master Cylinder Rebuilt, Brakes Bled, Discs Machined, Brakes Balanced and New Bendix Advance Brake Pads Fitted (I spent $978.00 on the Brakes, to get this done).
New Battery.
Genuine 119,000kms.
Arrived with GTS-T seats, GT-R seats can be fitted for around $700.
Front bar, front guards and side skirts need to be painted otherwise rest of the body is perfect.
Pictures are attached, please help of course I will pay to get it back if you have any info at all I will pay!!!!!
Call me anytime 0431-633-432.
Thank you.
Edited by sky88
https://www.sau.com.au/forums/topic/117614-stolen-gt-r-r32-1990/
Hi,
I showed someone 2 days ago the only person I have showed because I just got it ready to sell but I didn't show them at this address and yes it was stolen from my underground carpark, it had no plates and the fueses were taken out they must have got plates and gone out and got new fueses or shorted out the terminals and they even took my new battery out and left it on the ground, because they must have thought that was the problem why it wasn't starting so that means they must have gone out and come back with a new battery also I was only asleep 2 hours last night it must have been in that time!
This is the second car I have had stolen in 5 months, both with no insurance I couldn't even get insurance for this one because I hadn't even had a chance to compliance it yet.
Thanks.
HI,
Yeah what good do cameras do anyway they flim a couple of guys with hats on, then usually they would never get their faces and if it does the chances of finding out who they are is hard.
Just Jap had awsome pictures of the 2 f**king assholes that stole all their stuff what happened to that I don't think anyone has been caught at all, and they can afford to offer a big reward I can't offer that much that was all the money I had.
Thanks.
Edited by sky88
Good luck with getting your car back.. who would have known the car was in the carpark? can you see it from the street.. if not - than there is a chance it could be someone in your building that helped organise it..
if they took your battery out - it would have prints on it if they weren't wearing gloves..
Hi,
Yeah I am trying to get the cops out here to fingerprint it, but no luck at this stage they said they might think about it, and to just investigate myself because the boss won't want to pay to investigate, can you belive that if it doesn't make the cops money they don't want to know.
Who knows someone could have seen me drive in, I am chasing leads myself we pay an insane about of tax in this country and what do you get for it, the cops basicly tell you to go f**k yourself ?
Thanks.
inside job
This is why u check the footage.
If it is someone you know, this will help.
It's highly likely its someone who knew where the car was, rather than a "random oppurtunity" passer by.
Good luck with the search and keep looking, my car was stolen last year and found 6 days later, with minor damage.
Thanks guys for giveing a shit cause the cops don't, I am offering a reward of $2000-$3000 maybe more whatever if you can find it of if you know someone trying to sell GT-R parts some panels were a dirrerent grey faded style so they should be easy to find if someone tries to sell them.
And yes this was the second one this year !
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
