Hey folks
I have a question regarding something that's been bugging me for quite some time.
I drive to work very early in the morning (5am) in my R33 GTST, and have noticed that the car takes aaages to warm up properly (by properly, I mean temp gauge past 1/4, oil gauge ~4). And by ages I mean 20 minutes.
During the day, it only takes around 5 minutes of light driving.
When I first turn it on, i let it idle for around 30 seconds before driving.
Mods: Full exhaust, Pod (for now :) ), boost solenoid grounding
https://www.sau.com.au/forums/topic/117617-car-not-warming-up-in-cold-mornings/
I do suggest you let it idle for more than 30 seconds before driving. On a cold morning especially now as its freezing turn your car on and just let it warm up while your getting ready to go to work :) once you get back to your car she is all warm and ready to take you to work :D
Cheers for the replies guys
Maybe your thermostat needs replacing.... it could be stuck open..
I've thought of that, but wouldn't that also mean it would take a long time to Warm up during day hours as well.
It's only like that in early mornings (ambient temp ~10C)
  • 1 month later...
I have a similar issue, and it's obviously not as noticeable on a warmer day as the ambient air is of a higher temp, as such it warms the engine faster. I suspect that the thermo is busted/stuck open and would like to check and replace as necessary, has any seen/done this process? I'm looking for a tutorial. I can drive from my place to work (around 20mins) after letting my car idle for 5mins and the temp guage will only J'just' be scrapping to the 1/4 mark, it usually sits a bit under half when it's nice and warm.
-undo bottom radiator hose off the thermostat housing, you'll only really need to undo the top clamp (thermostat housing is just behind where your water pump is)
-remove the 3 bolts off your thermostat housing
-remove the thermostat (it just pulls out)
-replace thermostat and make sure you get a new gasket for the housing, it costs around $2 for one.
NOTE: if the person who had it before you used gasket maker, make sure you clean it all off before putting the new gasket in. i used the new gasket plus a bit of gasket maker.. i dont see the harm.
-put it all back together in the reverse order... it shouldnt take more than 10 - 15mins, you'll lose a bit of coolant out of the head so have some ready to refill.
-top the water up, start the car, top up some more then bleed your system immediatley... then top up some more if needed.
dont forget to top it up some more.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
