can anyone tell me if the where one might find a set of these glass headlights for the R33? i'm sure we're all in the same boat with the discolouration of the plastic headlights on the R33. are they an aftermarket thing? or are they from the S2? if so, do they fit a S1? all info appreciated.
*updated* actually, i've just found out that apparently the series 3 GTR had a glass headlight assembly. does anyone know more info on this?
Edited by vannic
https://www.sau.com.au/forums/topic/117625-r33-glass-headlights/
yup no glass headlights.. its dangerous having glass anyways.. In terms of safety!! (this is what i have heard and is probably true)
Now you can get those glass cleaner thingys for 20bucks, but takes a lot of effort to make it all shiny and back to normal.
Justjap apparently sell them..
Also wondered why it happens, and its only one side and not both?? anyone know?
I can clean the outside no problem, but the inside is starting to get that yellow haze everyone bitches about.
Apparently you can pry the headlights open by putting them in the oven & separating the parts when the glue melts, but there's no way I trust myself to do that. Might get them cleaned professionally later down the track.
Have you tried a Nissan Dealership that sales import parts. On previous occations i found new parts CHEAPER than second hand parts :P
that's true. my local nissan dealer (ferntree gully) deals in import parts which completely surprised me. however, i think a new headlight assembly would be big $$$. might be worth asking tho.
Car Toys offers a Headlight Treatment for $99 a Pair.
Tell them Dale from PSI Parts sent you.
Here is the description of there service.
Most cars these days use plastic headlights that eventually discolour with use and UV from the sun. Japanese imports such as Nissan Skylines & Silvias, Toyota Supras & Soarers are often particularly discoloured, affecting light performance. Our 'rejuvenating Process' brings them up almost like new, and the ultragloss coating adds protection for the future, with greatl improved optical clarity.
$560 per assmbly!! just look at my avatar mmm nice clean lights haha
try adding some car wax/polish on them a few times, i did this with mine and i noticed them go really clear.. make sure you wash them on the outside before adding the polish.. this will shine them up(give them a clear look), but wont affect the discolouration from the inside..
Edited by MKDR33
well my mate brought a sedan and has stained covers, very simple to fix, follow this procedure.
1. Buy a Automotive body cutting compound. The stuff you use as a first polish on a car after a new paintjob, it is quite corse and green. Apply to rug and polish the plastic. Do this by hand, or with a non-rotating buffer. A rotating buffer tends to swirl to much. Once the polish is dry buff off.
2. Get some normal cut and polish, form autobarn, cheep stuff is ok. Apply and buff and polish as per normal. Do this twice, possibly 3 times.
3. Get some GLASS POLISH, it is used for polishing windows. Autobarn has this. Apply as per instruction. Depending on how well step 2 worked, you may only need to do this once.
I have no pics but my mate was stocked and the covers look like new and very shinny.
PS. I take no responsability if somone stuffs one up, but i has worked for us.
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
