Hi,
My mate just bought a 2002 model 200sx. It is fully standard and is automatic. I was reading that they go 0-100 in 5.6 seconds standard. I have a R32 manual and i read that they go 0-100 in 6.5 standard. The mods i have are:
R34 Turbo - Running on 7psi
Lighten Flywheel
3 Inch Excust
K&N Air Filter
Front Mount Intercooler
I was just wondering if you guys think I can beat him with the mods I have?
https://www.sau.com.au/forums/topic/117627-r32-skyline-vs-200sx/
Personally i think it will come down to driver.. the auto will be quicker off the mark however it depends on how well you know to drive your car. stock 200sx has around the same rw/kw as a stock R32 however the RB20 should have more torque. The auto 200sx are pretty laggy until 4000rpm... Considering your mods you should be able to get him, if not let me drive your car :) hahaha just kidding... the only way to find out is down the 1/4 mile.
Regards,
Sarkis
You will chop him very very hard with those mods against an stock auto s15. You have manual vs auto, a bigger turbo and modifications done!
Standard the s15 sr20 would have quiet alot more torque than a standard rb20 though Sarkis.
Anyway go and find out mate, im sure you'll be happy with the results :)
Accordin to most dyno's and Nissans figures the sr20 has more torque, maybe due to more compression in the motor or 4 bigger pistons compaired to 6 smaller ones? Who knows but from what ive seen sr20 does have more torque (more noticable off boost than on)
actually remember that in australia the s15 sr20det was detuned from the factory. and in manuel form will do 6.34 and a standing quarter of 14.59.
Australian spec s15 has 147kw and 265nm of torque@48000rpm. Rb20 got few more KW's but same torque. S15 manuel weighs in at 1282kgs.
about the same asa 32
R32 Manuel will do 6.5 and 14.8 quarter. Expect only 0.1 to 0.2 seconds slower for the auto s15.
If your mate got rid of nissans state of detune he would be making 187kw and be running 13.8 quarters.
Youll woop him if you can drive properly if you got those mods you listed
They're no chance in hell a stock S15 can run 5.6 0-100km/h taking into account the car is an australian model and is auto.
The Jap S15 came with a ball-bearing T28 as opposed to the plain bearing of the Aus S15's.
Taking into account your mods I'd say you'd beat him easily. But mate why don't you just go out and have a run? Its all fun and let us know how you go.
Japanese spec S15 manuals ran 0-100 in about 5.6 as you stated - they have 184kw as standard. The Aussie cars were detuned to 147kw, and do 0-100 in low 6's in manual form. The auto's are slower again, with 0-100 in the 7's. A stock R32 GTST manual would chop a stock S15 auto very easily.
But then that raises another question - why are you running LESS boost than a stocker? Dunno too much about modifying cars, but your set up seems good for around 1 bar boost if you ask me! BOOST THAT SUCKER UP!!!
Edited by Big Rizza
Thanks Guys,
Ive ordered a boost controller and should be getting a new fuel pump in the next 18 days. My mate wants to have a drag in about 2 weeks so hopefully I will have it boosted when we drag. Although I should be able to win with it running on 7psi. I wont be happy if he does beat me. I might have to practice my take offs. Could i turn the boost up a bit without the bigger fuel pump?
Thanks
Yeah i will proberly run it on 10psi when i get the boost controller.
But then yesterday when I was driving the metal plate that holds my clutch in position snapped. So now i gotta take out the clutch pedal and cylinders to fix it all up. Hopefully it will be a easy job and somewhere will have the brackets to buy. Has anyone installed a Clutch pedal before?
My mate got his 200sx back the other day and wont take me for a drive. He has taken everyone else but me. I think he doesnt wanna show me how quick it is becasue it might be slower. Im pushing him to take me but my mates who have been in it say that mine is quicker anyways.
Also some how the bracket that holds my clutch twisted and snapped. Not sure if becasue it was mounted wrong or because the heavy duty clutch was to much pressure. I bought a new one which cost me $220, hopefully I wont have the same problem.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
