Hi all, I was wondering if someone could shed some light on this topic for me....
I notice when people go for twin turbo setups for "light tune" GTRs, they seem to go for things like disco potatos etc. Recently a mate of mine asked what would be a good turbo to go for on their Starlet GT, saying they wanted a good streetable turbo which would let them get ~270hp @ crank. He had been looking at GT28 style turbos, so I went and had a look at some compressor maps and made some wild estimates.
Something interesting I found, is that at least the way I was estimating the flow of the motor etc - SMALLER turbos seemed better suited to the 1.3, but at higher pressure ratios. Funnily enough... almost so much that a GT28RS would be a worse choice than a much smaller turbo for the same power level, as at the boost level required surge lines get precariously threatening etc - but the motor didn't look like it would breath enough in the "top end" to make the size of the compressor wheel at any given pressure ratio worth while.
I looked around at other maps, and feel apon the GT22 with 59.4mm 52trim compressor wheel - which for the same pressure ratios (up to around 2.5) SEEMED by my loose estimates to be a lot more sensible.
After that, I pondered the fact that half an RB26 might be a bit better flowing up top than a 4EFTE - but not HUGELY so. When matching a pair of turbos to a straight six, should you treat it like a pair of 1.3s? Because if my assumptions are remotely correct - that GT22 turbo could actually be quite a nice match to the RB26 for a mild upgrade over the stock turbos?!
GT22 Map
https://www.sau.com.au/forums/topic/117645-choosing-suitable-twin-turbos/
you cant really treat it as 2 1.3l motors, as the exhaust pulses are different, and the final inlet is merged into a common collector (plenum)...and the flow of a 8000+rpm 3cyl motor would not flow the same anyway.
Guest Mashrock
if your after crank power with the 550hp, something along the lines of hks 25/30's or the largest sized r34 n1's possibly even gtss turbos.
but your also going to need some supporting mods to give them that top end in say the 34n1 and gtss.. i am not sure about the 25/30's tho as they are a wee bit bigger than the later two.
Two of that turbo would not get you to 550hp.
You would be lucky to get around 27.5 lb/min out of it at a decent efficiency. That would give you no more than 500hp for a pair.
Look at the 2530 sized garretts (which I have for sale :P)
Theyre good for about 35lb/min of air, and are thus rated at around the 600hp mark (id say).
If you want something streetable, go the ss's. If you dont mind a bit of lag, the 2530s arent bad and give good power. Dont forget all your support mods to get to that power level !
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
