  • Replies 46
last but not least!
Yeah see what i have to put up with Dark - thats why i have two too even the score around here! You think whats under the carport is bad should see the shit they keep in the house with holden all over it!
nah my folks - im an only child. We also have a 356 porsche with wide body kit. But didnt get any photos of it at the time. I have two cars mum has two cars and my dad has the HSV and a go-kart haha
Just a family of car enthusiasts! Been dragged around to car shows ever since i could walk.
yeah when i just had my 300ZX and worked for caryard - the wife of the guy that imports cars comes up to me and goes "thats a really nice supra you have" and im like .... what tha? you import them you ought to know it aint a friginn supra!!
Anyway on the new 350Z ad - it starts off with one that looks like my Z31 evolves into the Z32 and then the 350Z.
yep thats right - at one point dad wanted a motorbike but thats was until mum gave him her permission to have one - he lost all interest after that! haha.
Yeah we've got the room to garage them even tho u can only see one carport which is where the two HSV's go in the picture. We've got one beside our house and we can squash another 5 cars down there.
Its like tha tlotto ad where they go "can you move the porsche so i can move the lamborgini to get to the torana - y eah alright but move the holden to get to the ....... ahhh you get the idea but it gets a little like that round here sometimes!!
to tell you the truth my Z31 can eat my skyline for breakfast! which means theres a lot to do on the Line to get it up to the standard of quickness im used too! Althought the Z31 handles like a dinosaur which makes it a little dangerous - in fact its almost become my coffin a few times!
to tell u the truth its gone on the dyno to sort out a fuel prob but i dont really know. Most mechanics dont even want to look sideways at it because its a total speghetti factory under the bonnet! got pics of that give me a moment and i shall post the spag factory.
I would like to plug Rotomotion tho for fixing one worskshops mistakes - i took it in this workshop fully working with a slight fuel smell after 3 weeks my ex marched in there an demanded it back - the guys were so lazy that rotomotion found manifold bolts just chucked under the windscreen. They fixed the whole mess up - and what a mess it was! They are great mechanics!!
V6 Turbo. haha Joe u think my Skyline sounds like V8 you should hear this car - its as loud as - its one of those wonderful cars that you drive close enough to another car it sets off the alarm haha i used to have so much fun doing that!
Skyline does have more power in the top end but this car the boost almost send you thru the windscreen - but it kinda gets over and done with early one where the skyline you still can access more power when you're doing 120. dont know whether that makes much sense but i know what im talking about at least :) haha
heheh my yeah I know what you mean setting off alarm heheh...
I used to do that at my place car park...
late night back from partying, at least set off 5 car alarm :)
it's fun until some one complains to the landlord hehe :D
but then again you can not beat the sound commming from 7000 rpm rev limiter ;)
cheers
JOe
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
