Ever since i got a GFB Hybrid BOV installed with a pod it stalls... very frustrating as it also does it on the freeway.
I have plumbed back the GFB (has full plumback feature) but the car still stalls... sometimes you even try to rev it and it just wont go past 3 000rpm... very annoying and can feel backfires (this was on full atmo setting).
I will take off the GFB BOV tomor and fit my stock bov on... I hope this will fix it up... if not then perhaps the pod can also cause the car to stall??? its unshielded... so may need to fit the stock air box on.
Can anyone shine some light on this?
https://www.sau.com.au/forums/topic/117687-car-stalling/
weird.
I got HKs SSQ bov just installed yesterday.
no stalling or idling funy,
Just make sure you block off the blumpback hose tite, no leak, and make sure the vacumm line to the BOV is tite and secure, and all adjustment on the BOV should be tite.
those factors caused idle funy for my BOV.
but all sweet after that all sorted.
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2165254
they sometimes stall because when when they vent to the atmosphere there's air that goes past the afm but doesn't get to the engine. But you said that you switched it to plumback. So therefore it shouldn't be stalling, I'd be looking at a leak somewhere perhaps?
But yeah, good idea would be to put the stocker back on, and then see what happens. Then you can see if it's the BOV or the piping...e
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2165353
ughmmm urs is auto yeah? hmm weird. ive got n aftermarket bov on mine ( blitz type s ) and pod and my cars never stalled before. are u sure whoever put it on put it on correctly?
Yep, auto. A pro put it on. Anyway I took the aftermarket BOV off today and put on the stock BOV and then drove around the block... still stalled... at low rpm, around 40 km/h. Then we discnnected the battery for 5 mins to reset the ECU... all good, then I fanged it past 7000 RPM and stalled shortly after... I then drove for a few hours and no problems what so ever... except when i got home just before, I set the turbo timer on 3 mins and the car stalled after 2 mins on turbo timer... really wierd!!
I dont know what to do, maybe its the pod also? Its unshielded! She never stalled before I put the BOV and pod on... whats a good way to tell if there is a leak... i think maybe a tune or ?
Ill see how the car will behave over the next few days... then if still stalling i may put the stock air filter on... or get the guys to check it out at the shop.
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2165730
AFM = air flow meter
its near ur air filter,
its the 1 that have meshs, with a plug connected to,
try to pull out while the car is idling,
see if it does anything strange.
could be ur have a leak somewhere,
maybe a vacumm hose is not connected.
unshield pod wont contribute to car stalling~
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2166319
Hummm.... I got a 34 GT-t Tiptronic, I also have a GFB Hybrid BOV, I have had it installed for about 15 months, it has been all good till now.
However recently I have also noticed my idle is going really low too, its stalled twice in the last 2 weeks, I am taking mine to nissan so they can connect it up to their computer to see if theres anything else wrong with the car. just as a precaution.
I checked all my hoses and couldent find nothing....
Let us know how u go if u do find the problem, likewise ill let u know wat Nissan say.
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2182459
I have a GReddy Type-S atmo BOV on my auto.
My car used to stall a fair amount - everyone said it was the BOV but even when I plumbed it back it still still stalled.
Fast forward to getting a SAFC installed - no stalls now and I'm still running an atmo BOV.
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2182721
Ok checked the coils and they are silver inside... no dirty stuff!! So obviously not the coils!
Gonna check fuel filter, afm and fuel pump today...
Also went for a drive yesterday doing 60-70 Km/h without boosting past 2.5 K and the car was fine...
Edited by Sir-D
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2184605
Check your diagnostics first on your ECU. Usually if its an electronic fault then it will tell you. Do this first before you fiddle around with everything.
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2185735
Usually it's the AFM, get it out and spray it with WD40 (those lubricant that u use to loosen stuck screws), spray at the middle part of the AFM which is like a little door hanging with two thin lines, and make sure you wipe the nets (exterior) clean. plug it in and test your car, if still stall try changing with your friend's AFM (must be same engine, you should know this right?) and test your car again, if it doesn't stall that means you must get a new one. If it's not the AFM, check your ECU (exchange with friend's and see). If it's not either of these, check your fuel pump
https://www.sau.com.au/forums/topic/117687-car-stalling/#findComment-2192363
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
