Anyone broken their remote rear seat handle in the boot ? seems pretty fragile for the force required to pull the cable and release the seat. Also, realised today that the rear seat can be laid back for extra comfort, using the handle next to the seat. thought that the rear seats were a little too upright.
https://www.sau.com.au/forums/topic/117693-remote-rear-seat-lever/
Mines not broke, but then I dont get to use them often with 3 baby seats and all. If you have to pull harder then one finger then you got a seized cable or locking mechanism problem.
Yes, reclining rear seats are just another sweet Stagea touch, designed by someone who actually thought about what might be useful.
Now that you've broken it - what's it made of - plastic or metal?
Edited by 3intheBack
Mine dont need much force at all to get them to work.... Also my kids found the recliner lever and now proceede to change it constantly to match their mood I guess.
I guess they copy me as first thing I do when I get in is seatbelt, then make tiny adjustments to mirrors and seat and then start her up.
I broke one of mine ;) cost $68 for a new one from Nissan.
That's not too bad seeing this on yahoo japan.
Around $50AUD purchase price only.
I have a feeling you may have paid $68 for the plastic handle only though...
Edited by munchdesign
Nope, it came complete, handle, bracket and cable :(
  • 2 months later...
Well my passengers side lever went this morning, went to drop the rear seat, didnt yank on it or anything, and snap.......
So what is the part number, for the passengers side one, I'm guessing the drivers side and passengers side will have different part numbers?
hey cyrus dont u reckon a dedicated sticky thread with stagea part numbers for parts us members buy would make it very easy and handy for others when it comes to ordering bits and pieces. im talking all parts like manual console surrounds, to these handles, and cargo covers, and anything inside or outside the stagea :miner: virtually a nissan fast part no. thread to save the nissan dealers from trying to find part no's on the Fast programs.
good or bad idea? :rofl:
cheers
Brad
cheers
Brad
i think its a great idea save the screwing around and stuff
hey cyrus dont u reckon a dedicated sticky thread with stagea part numbers for parts us members buy would make it very easy and handy for others when it comes to ordering bits and pieces. im talking all parts like manual console surrounds, to these handles, and cargo covers, and anything inside or outside the stagea :P virtually a nissan fast part no. thread to save the nissan dealers from trying to find part no's on the Fast programs.
good or bad idea? :D
cheers
Brad
Already done, there is a parts list, the link is in the sticky mega link thread :)
Here ya go Ska, have replaced the same one in mine, cost bout $69, bit of work involved too, have to remove the complete rear left interior trim to get to it.
88925-0V015
Yes well I had to have a fiddle didnt I :angry:
Well after 4hours of unscrewing and removing bits and pieces I found out why my ATESA isnt working right, one of the wires had worn through and was shorting out on the body, so whacked a bit of electrical tape around it and zippy tied it away from where it had worn through.
Anyway, I followed the line through and near the release mechanisim on the seat itself there is a white bit of plastic which sits around the cable and then slots into the unlocking mechanisim, one side of it had broken off, the plastic was a bit detiriorated, so I whacked a bit of superglue on it and let it dry, hey presto, works like a charm :P
Then it only took about 2hours to get it all back in, :D What an adventure :)
  • 1 year later...
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
