Thought I might start the official dyno day thread,
This was the first dyno day I've ever attended and I had a great time and found it a great learning experience. I made 131.9kw on my stock 32gtst, which I'm pretty happy with as I was expecting about 110/120ish, everything seems to be healthy :D
I don't have any pics or videos unfortuantly because I forgot the camera so lets see everyone elses :)
Post up your results and tell us how you did.
Thanks to the guys who organised this, and racingline performance :(
https://www.sau.com.au/forums/topic/117704-dyno-day-wrap-up/
Yeah i was a great day....
It was my first time on the dyno also .
I never expected a lot so was not freaked out at 135kw.on a stock R33 sedan (auto)
It gives me plenty to do now. Spending some $$$ might be a good start.
Let me say thank you to the guys down at RACINGLINE MOTORSPORT. and the other organisers
......................................................................Cheers
100_3321.MOV
First let me give a big thanks to Nigel and his friend (sorry didn't get your name), at RACINGLINE, for holding the dyno day. Great guys and great new w/shop, wish you both a prosperous future in you new endeavour.
The day was a huge success, with cars on the dyno continuously. Met a few new guys and hope to see you all at our cruises/events.
On a personal note; i stayed till the last car and left with a grin from ear to ear :). Due to my 19's i expected a lowish figure, i knew my tune was dropped to about 250'ish rwkw with 16" rims, so i expected a figure at 230rwkw. The car made 240.Xrwkw, with what was referred to as hugely rich A/R ratios :D. There may not be much power to gain up top, but there is alot to be desired mid-range. After having a chat to Nigel, i stated that "my mechanic probably wanted to keep the engine safe". His reply of the day: "there is safe but yours is just wasting fuel" :(.
I believe i may have made the highest figure for the day, so i am pretty damn happy!
I have decided to give this set-up one more tune, before i install the GT-RS, just to see if i can gain some more response for DECA.
Below is a graph comparing my tune to Pete's, the quality difference in tune is obvious.
i think i took home the wooden spoon, with a whopping 96.9 rwkw!
was stoked with such a shit effort... lol!
turns out my cars pumping out hugely lean afr's of 16 :)
apparently it shouldnt even be alive! haha
WHERES MY SPOON DAMNIT!
I came down very early then had to leave :)
First run of the day, my mates HR31 pulled 130rwkw with a Redtop NICS, RB25 turbo @ 10psi
I went on second, made 180rwkw, all going through a big fat auto. Silvertop ECCS, GT2871r @ 16psi...AFR's up the creek :D
Thumbs up to the workshop and Nige who seem like good blokes. I will be definitely going back there to get my SAFC tuned.
This was the first dyno day I've ever attended and I had a great time and found it a great learning experience. I made 131.9kw on my stock 32gtst, which I'm pretty happy with as I was expecting about 110/120ish, everything seems to be healthy :(
I don't have any pics or videos unfortuantly because I forgot the camera so lets see everyone elses :P
Thanks to the guys who organised this, and racingline performance :)
I told you that you'd get 130 :)
good turnout and a fair few new faces, which is always good.
thanks for racingline for putting on the day, the organisers and people who came to the event and helped out. a very sucessful day.
i made 167rwkw and then finally 182rwkw after some more timing which was thrown in. we tried the R33 VCT tuning and there was no noticable difference so it was left as defaults.
thanks for those who helped organise and run the event
turns out my cars pumping out hugely lean afr's of 16 >_<
time for a new fuel pump dude! :D
is that what nigel said?
turns out my cars pumping out hugely lean afr's of 16 :D
rwkw...
dont you have a gts4? >_<
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
