Thought I might start the official dyno day thread,
This was the first dyno day I've ever attended and I had a great time and found it a great learning experience. I made 131.9kw on my stock 32gtst, which I'm pretty happy with as I was expecting about 110/120ish, everything seems to be healthy :D
I don't have any pics or videos unfortuantly because I forgot the camera so lets see everyone elses :)
Post up your results and tell us how you did.
Thanks to the guys who organised this, and racingline performance :(
https://www.sau.com.au/forums/topic/117704-dyno-day-wrap-up/
Yeah i was a great day....
It was my first time on the dyno also .
I never expected a lot so was not freaked out at 135kw.on a stock R33 sedan (auto)
It gives me plenty to do now. Spending some $$$ might be a good start.
Let me say thank you to the guys down at RACINGLINE MOTORSPORT. and the other organisers
......................................................................Cheers
100_3321.MOV
First let me give a big thanks to Nigel and his friend (sorry didn't get your name), at RACINGLINE, for holding the dyno day. Great guys and great new w/shop, wish you both a prosperous future in you new endeavour.
The day was a huge success, with cars on the dyno continuously. Met a few new guys and hope to see you all at our cruises/events.
On a personal note; i stayed till the last car and left with a grin from ear to ear :). Due to my 19's i expected a lowish figure, i knew my tune was dropped to about 250'ish rwkw with 16" rims, so i expected a figure at 230rwkw. The car made 240.Xrwkw, with what was referred to as hugely rich A/R ratios :D. There may not be much power to gain up top, but there is alot to be desired mid-range. After having a chat to Nigel, i stated that "my mechanic probably wanted to keep the engine safe". His reply of the day: "there is safe but yours is just wasting fuel" :(.
I believe i may have made the highest figure for the day, so i am pretty damn happy!
I have decided to give this set-up one more tune, before i install the GT-RS, just to see if i can gain some more response for DECA.
Below is a graph comparing my tune to Pete's, the quality difference in tune is obvious.
i think i took home the wooden spoon, with a whopping 96.9 rwkw!
was stoked with such a shit effort... lol!
turns out my cars pumping out hugely lean afr's of 16 :)
apparently it shouldnt even be alive! haha
WHERES MY SPOON DAMNIT!
I came down very early then had to leave :)
First run of the day, my mates HR31 pulled 130rwkw with a Redtop NICS, RB25 turbo @ 10psi
I went on second, made 180rwkw, all going through a big fat auto. Silvertop ECCS, GT2871r @ 16psi...AFR's up the creek :D
Thumbs up to the workshop and Nige who seem like good blokes. I will be definitely going back there to get my SAFC tuned.
This was the first dyno day I've ever attended and I had a great time and found it a great learning experience. I made 131.9kw on my stock 32gtst, which I'm pretty happy with as I was expecting about 110/120ish, everything seems to be healthy :(
I don't have any pics or videos unfortuantly because I forgot the camera so lets see everyone elses :P
Thanks to the guys who organised this, and racingline performance :)
I told you that you'd get 130 :)
good turnout and a fair few new faces, which is always good.
thanks for racingline for putting on the day, the organisers and people who came to the event and helped out. a very sucessful day.
i made 167rwkw and then finally 182rwkw after some more timing which was thrown in. we tried the R33 VCT tuning and there was no noticable difference so it was left as defaults.
thanks for those who helped organise and run the event
turns out my cars pumping out hugely lean afr's of 16 >_<
time for a new fuel pump dude! :D
is that what nigel said?
turns out my cars pumping out hugely lean afr's of 16 :D
rwkw...
dont you have a gts4? >_<
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
