Hi guys, today when I was just having a general look in my engine bay I noticed that one of the rubber hoses coming off my bleed valve was melted to the turbo and had a massive hole in it, the car seemed to drive fine on the way to work this morning and was boosting and holding boost fine so im not sure what this melted hose could of done but I replaced it anyway.
Now anyway as I looked around the engine bay a bit more I noticed their was oil in the vent bits of the BOV (aftermarket Apex'i bov) I then noticed that their was a lot of oil leaking out of one of the intercooler pipes at the bottom of the cooler, this oil is MUCH blacker then the oil thats on the dipstick. I wiped all this oil off and took the car for a short drive and everything seemed fine it wasnt blowing any smoke at all or anything but when I got the car back I had another look and their was more oil leaking out of the bottom intercooler pipe joint bit.
Anyone have any idea what this could be from?
Car is a 1993 RB20DET R32 GTST
Power FC
Bleed Valve, 14psi
GTR Front Mount
Turbo Back Exhaust
Thanks guys!
Turbo seal is the likely culprit. Clean away all the oil you can see and check it in a few days. If it comes back its most likely time to get the turbo seal fixed/replaced.
It could be a once off and may not occur again. If it does come back in a few days you could also turn the boost down a little bit to take some stress off the turbine shaft (rotation speed)
do you have a oil catch can? it could be a bit of blow by
if the pipes that come out of your rocker covers go back into the pipe that runs off the compressor housing and your getting blow by,
that would be the reason for the oil in the cooler and it would be in the turbo and most likely in your throttle body and plenum if you have oil in your bov!
blow by is caused by seals leaking or shagged internals.
having a catch can will capture the oil thats getting in the intake but the original problem is still present, ie: shagged internals or seals.
you are much better off fixing the source of the problem, as apposed to fitting a catch can and just catching the excess oil blow by. if you have oil in the intake piping, something is wrong, is about to fail or is showing signs of fatigue, utlimately it will fail or go bang if it continues
what he said. >_<
you do get a bit of oil up there sometimes after maybe a hard track day or drags, but if your taking it easy and your getting alot of oil you have some problems
    • Also sorry to hear this @DanielStone - I remember @SmoothLine well, he was around for a very long time and was one of the original members of this site.  God Speed Matt. Thoughts with his family and friends.
    • Nice car! Looking at your GTS; makes me wonder why I bought a GTS-t... Everything has been changed anyway. I should have just started with a non turbo model.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
