Hi All,
Has anyone used/got a Tomei HICAS Lock System??
http://www.nengun.com/catalogue/product/60
I am thinking about getting one, but would like to hear of any experiences with them first..
especially:
1) Is it easy to install yourself?
2) Are the results noticeable? (worth the money) ?
Any feedback is greatly appreciated..
cheers,
-JD
https://www.sau.com.au/forums/topic/117798-hicas-lock-system/
Geoff is not making those lock bars anymore and no longer has any stock of lockbars for the R33, although he appears to still have some for the R32.
Anyways, you can still purchase a solid bar through http://www.greenline.jp
It is called an ESSENTIAL HICAS Breaker.
Anyways a little off-topic to the original question, honestly do a search as I have read numerous threads on locking hicas and plenty of posts on experiences with the Tomei kit.
hmm i was looking at the same kit and it doesnt seem that its a locking bar. Tried mailing them but there reply to me wasnt very helpful >.<
"tomei HICAS lock" in search function turned up about 3 mentions. But none explained how it would work considering it doesnt have a locking bar and the hicas system on the 32 gts-t is hydraulic and not electrical.
So any one who is more apt with the search control please post :P I know that its a relatively popular kit but basically i want 0 movement from the back and wanted to know if this woulda achieve it
thx
My Essential lock bar arrived today :D .
The Tomie kit just locks the hicas rams in the out position with big washers (sydneykid has a few threads on how to copy the tomie kit for free), but it leaves the entire system in place. But a lock bar drops the HICAS rack out, and replaces it, saving weight.
ahh icic, i cant see the hicas weighing more than 5 kilos so im not to worried bout that, ill get the tomei kit (i dont REALLY like removing things that dont came on the car standard) Tried pming GTRgeoff but all i got for a reply is "No" so either he doesnt stock them or make them or has none for 32 gtst
Edited by r32 gts-turbo
I heard the lock bar makes the steering feel heavy on the R33? Can anyone confirm if this is true or not?
i think you are confusing your power steering with your hicas unit....lol. If you remove your power steering, yes your steering will get heavy.
I had noticed no difference in the weight of my steering when my lock bar was put on.
Well yes I do know the difference between power steering and hicas, I have read and heard that once hicas is removed (R33), steering become a little heaver as Greg has pointed out :P
thanks for that info Greg
Edited by woolls
Well yes I do know the difference between power steering and hicas, I have read and heard that once hicas is removed (R33), steering become a little heaver as Greg has pointed out :wave:
maybe every car is different.... as I noticed little difference at low speeds
There is quite an obviuos difference between P/S and Hi-cas. When the Hi-cas is removed, some people remove the control unit as well unaware that it also has a role to play in the P/S system. The control unit controls the speed dependant power assisted steering (makes the steering light at low speeds and gradually assists less as you go faster making your steering heavier and giving more feel.). So when you remove the control unit, you also remove this function. so it defaults to the heaviest setting all the time!
Hope that helps! :wave:
Some extra castor on the front almost completely removes the heavy steering that can sometimes occur when removing HICAS. Usually it's only at really low speeds so doesn't bother most people. Extra castor is essential to help your car turn in properly instead of thinking about it then having a go a fgew minutes later :wave:
I tend not to respond to PM's. Nothing wrong with email.
The little black box thats a part of the tomei kit, when installed corrects the slow speed heavy feeling. I had heavy steering as my hicas was on/off, but i put the tomei kit in and its all good now.
No heavy steering at all. It still lets power steering errors apper though (as my speedo stopped working), and the hicas light came on.
This is better than just ripping out the hicas, and removing the globe from the dash.
Well, not if you are using it in a race car, which is the intended recipient for my bars that weigh 0.73kg and 32's can save over 20kgs with all the crap removed.
I only offered bars to road car drivers because they were so expensive at one stage and fixing HICAS can be expensive and is no guarantee it won't go haywire again at some stage. Unfortunately too many think it's just another piece of rice, but I do attempt to weed them out, usually the ones asking for pictures.
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
