Hi All,
Has anyone used/got a Tomei HICAS Lock System??
http://www.nengun.com/catalogue/product/60
I am thinking about getting one, but would like to hear of any experiences with them first..
especially:
1) Is it easy to install yourself?
2) Are the results noticeable? (worth the money) ?
Any feedback is greatly appreciated..
cheers,
-JD
https://www.sau.com.au/forums/topic/117798-hicas-lock-system/
Geoff is not making those lock bars anymore and no longer has any stock of lockbars for the R33, although he appears to still have some for the R32.
Anyways, you can still purchase a solid bar through http://www.greenline.jp
It is called an ESSENTIAL HICAS Breaker.
Anyways a little off-topic to the original question, honestly do a search as I have read numerous threads on locking hicas and plenty of posts on experiences with the Tomei kit.
hmm i was looking at the same kit and it doesnt seem that its a locking bar. Tried mailing them but there reply to me wasnt very helpful >.<
"tomei HICAS lock" in search function turned up about 3 mentions. But none explained how it would work considering it doesnt have a locking bar and the hicas system on the 32 gts-t is hydraulic and not electrical.
So any one who is more apt with the search control please post :P I know that its a relatively popular kit but basically i want 0 movement from the back and wanted to know if this woulda achieve it
thx
My Essential lock bar arrived today :D .
The Tomie kit just locks the hicas rams in the out position with big washers (sydneykid has a few threads on how to copy the tomie kit for free), but it leaves the entire system in place. But a lock bar drops the HICAS rack out, and replaces it, saving weight.
ahh icic, i cant see the hicas weighing more than 5 kilos so im not to worried bout that, ill get the tomei kit (i dont REALLY like removing things that dont came on the car standard) Tried pming GTRgeoff but all i got for a reply is "No" so either he doesnt stock them or make them or has none for 32 gtst
Edited by r32 gts-turbo
I heard the lock bar makes the steering feel heavy on the R33? Can anyone confirm if this is true or not?
i think you are confusing your power steering with your hicas unit....lol. If you remove your power steering, yes your steering will get heavy.
I had noticed no difference in the weight of my steering when my lock bar was put on.
Well yes I do know the difference between power steering and hicas, I have read and heard that once hicas is removed (R33), steering become a little heaver as Greg has pointed out :P
thanks for that info Greg
Edited by woolls
Well yes I do know the difference between power steering and hicas, I have read and heard that once hicas is removed (R33), steering become a little heaver as Greg has pointed out :wave:
maybe every car is different.... as I noticed little difference at low speeds
There is quite an obviuos difference between P/S and Hi-cas. When the Hi-cas is removed, some people remove the control unit as well unaware that it also has a role to play in the P/S system. The control unit controls the speed dependant power assisted steering (makes the steering light at low speeds and gradually assists less as you go faster making your steering heavier and giving more feel.). So when you remove the control unit, you also remove this function. so it defaults to the heaviest setting all the time!
Hope that helps! :wave:
Some extra castor on the front almost completely removes the heavy steering that can sometimes occur when removing HICAS. Usually it's only at really low speeds so doesn't bother most people. Extra castor is essential to help your car turn in properly instead of thinking about it then having a go a fgew minutes later :wave:
I tend not to respond to PM's. Nothing wrong with email.
The little black box thats a part of the tomei kit, when installed corrects the slow speed heavy feeling. I had heavy steering as my hicas was on/off, but i put the tomei kit in and its all good now.
No heavy steering at all. It still lets power steering errors apper though (as my speedo stopped working), and the hicas light came on.
This is better than just ripping out the hicas, and removing the globe from the dash.
Well, not if you are using it in a race car, which is the intended recipient for my bars that weigh 0.73kg and 32's can save over 20kgs with all the crap removed.
I only offered bars to road car drivers because they were so expensive at one stage and fixing HICAS can be expensive and is no guarantee it won't go haywire again at some stage. Unfortunately too many think it's just another piece of rice, but I do attempt to weed them out, usually the ones asking for pictures.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
