Wrecking R33 GTST series 1.
* RB25DET..damaged sump, crank pulley, turbo has small hole, cam sensor, timing cover, a/c & power steering pumps PRICE DROP $700
* Passenger side door complete with trim and glass ****SOLD****
* Brake master cylinder $50
* Series 1 computer $200
* glove box $50
* Centre console with lid slight bend at front $20
* Centre vents $50
* Rear tailights black in colour *****SOLD*****
* Rear bar has some damage $150 black in colour price drop $50.. *****SOLD*****
* Front calipers with pads complete $200 *****SOLD****
* Rear calipers with pads complete $200 ****SOLD****
* Rear hubs with handbrake cables $150 ****SOLD***
* Rear bootlid with GTR wing no lock in boot $300
* Front seats $150 each
*Rear seat $100 complete
* Cluster with 76,000k's..broken tabs where screws go $70****SOLD***
* GTR style rear bar with pods to suit $300 *****SOLD*****
* Interior trims from $10
* Front disc rotors ******SOLD*****
* Rear disc rotors $50 pair*****SOLD*****
* Diff $200
* Tailshaft $100
* Rear hicas unit $100
* Power steering rack $100
* Engine crossmember $100
* Front hubs $100 pair
* rear windscreen with hole for wiper ****SOLD*****
* rear 1/4 windows $100 each
* door handles $25each
* Aerial unit $50 *****SOLD*****
* roof lining $50
Plus more..please PM for details or photos etc.
Located in sutherland shire.
Thanks....
Edited by sav
https://www.sau.com.au/forums/topic/117817-wrecking-r33-gtst/
  • Replies 90
Posted Images
ok try answer everyone questions.
* Sorry dont have a/c condensor
* i may sell wing without boot if wing comes off easy enough..i will have a look tomorro night.
* as for the brakes had a lot of interest in them so $600 as apackage..still good just checking the pads but i have 2 sets of rotors so will sell with the best ones.
* Sorry sooley this is the same one as before gearbox sold already
* the tailshaft snapped at the yoke but looks ok still..has the shaft then uni and broke after that $40.
i Mate,
Assuming the front brake rotors fit GTST series 2 I'd be interested.
Could you send close up photos of rotor condition
Cheers
David
0414-232497
dmgoodchild@optusnet.com.au
Edited by stealth
  CU-LOOZ said:
hey dont no if still available but interested in both rear hubs without discs and without calipers just the hubs are they available.
also is the power steering pump available
i have power steering pump though pulley i damaged $50
hubs sold sorry
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
