hey guys
need some good advice on what to do
well i just bought new injectors from here... and i looked at the engine and it looks like we have to take out the plenum to take out the fuel rails. does anyone here know that if we take out the plenum... will the gasket break or do we have to replace a new one. if it doesn't... then i can do a home job :D but if it does... i guess its more safer to get professionals to do it >.<
thx all in advance
https://www.sau.com.au/forums/topic/117819-help-on-changin-injectors/
i did my one my self, i hated it, bastard of a job, but labours expensive!! u need a 12 or 14mm socket and extention to get to the bottom studs.. i used a ratchet spanner for the easier ones.. good luck
i was only charger $250 for the job :D if u shop around u can get some pretty ok pricers :D
dam $250 for labour... thats alot aye...
thx for the reply...
also... umm... the top half of the plenum... if u unscrew it... does it stuff up the gasket.. anyone know ?
no its a rubber gasket. as long as it isnt ripped etc, re use it
You dont need to take the plenum off.
I've swapped injectors in 2 different rb25's and an rb20, about all you need is a set of pliers and a 1/4 inch socket set and you can slide the rail out the front.
It's a bit easier if you remove the throttle body. It's a 2 hour job max, including removing the old injectors, installing the new ones and reinstalling the rail.
Well going by your user name you have an R34.
The rail will not slide out the front without removing the plenum. It comes oh so close but I tried for ages and it wouldn't come. The gasket is not rubber either but if you're careful you can reuse it no worries.
There are 3 bolts holding it on from underneath and they are all bastards. You need a 1/4 inch drive socket set to get them out. I think they are 12mm but could be 10mm.
Impedance is an electrical term. Did you mean to use that? What injectors do you have and what engine?
yes i did because if the injectors are different the std ecu will not operate them properly, there is high impedance and low impedance injectors (99%sure of this?)
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
