I was looking into getting a DR Drift remap. however, then i found out the price. and if i was goin to have to remap after every mod after 3 mods i could of bought my self a powerfc.
I think if your goin to do something do it right the first time. but that depends on the person .
secondhandninja hopefully u wont have any problems with this remap. and good luck.
  • Replies 76
How is that any different to tuning the PFC every time you change something?
As long as your AFM is working correctly I don't see why this wouldn't work. The ECU calculates you need X amount of fuel for Y amount of air sensed by the AFM. Aslong as the AFM is accurate then the calculated AFR's should be the same as the actuals (or reasonably close).
The stock R32 maps go down to 10.6 AFR's (calculated), if you bumped with up to 11.5 I dout it would lean out aslong as your fuel pump was up to the task.
This ECU map guy seem way to risky for my liking.
Put it this way, Say u pay 300 for the chip and put it on ur car and for some reason ur car has unexpect results like i did when i got mine dynoed. What are u gonna do then? He cant come and remapp it for u to fix the problem (say too lean) so u will have to chuck the chip out.
At least with DR. Drift he tunes it on the spot and u know ur car will be running perfectly coz he will be tuning it to run perfectly.
Considering Dr.Drift charges 500 (i think) for the remapp, i would personally prefer to get the powerFC can have it tuned by some1 like RE customs. U pay 500 extra but at least the powerFc tells u when ur engine is knocking, when ur injectors are maxing out, when ur fuel pump is maxing out and whateva else it tells u. $500 is cheap for vital information like this
This sort of remapping has been done in japan for more than 10 years. it is a cheaper alternative to getting a PFC.
usually you get the best results from mild tried and tested upgrades like rb25 turb on RB20 or 2530 on RB20 and standard injector upgrades like gtr into RB20 or Z32 afm into RB20.
I have had a lot of remaps done and I have always been happy with em. because nobody knows you are running aftermarket management. easier on rego and $1000 less to fork out on mods.
There would be literally 100s of people on these forums running remaps and most are happy with them. It's all well and good to say PFC PFC PFC till you are blue in the face but it is proven that a remap works otherwise nobody would do it.
my 2c
there is nothing wrong with a remap, even our race cars run them. The factory computer has plenty of room for changes.
Tas084, the PFC tells you when its knocking, but the standard ECU sees it and does something about it (retards timing for you).....which do you think is a better idea?
yeah i am with you Duncan. i have had really good success with standard ECUs learning , Moreso on Rb30's
The Poewr Fc is a nice bit of Adjustable gear but it dosent offer a change of rule to A/R, Lambda or detination physics.... the correct values are always the same no matter whats driving the injector. If the standard Ecu has the scope the maths to HP is the same....
yea but power fc dose it properly.. and mapping the ecu has limits.. i dont want limits. so if im goin to spend $450 on something that gives me a quick power gain id rather put it to a powerfc.
You sound like you are an expert.
That is the biggest load of crap I have heard this year. The remapped ecu has a greater tuning capacity than a powerFC. The remapped ECU can do anything a powerfc can plus it has the added bonus of cold start, diagnostic error coding, knock retardation and adaptable tuning. PowerFC is dumb and only does what it is told. Even then, any man and his dog can tune one and charge $500. Have a guess at the quality of tune you get for that though.
Dr Drift has remapped literally hundreds of factory ecu's including mine (450hp RB20), one of the recent drift national champions (500hp RB20), 400awkw GTR's, widespan sheds drift S13 (320hp CA18) etc, etc.
My 2c
  • 5 months later...
I am thinking of upgrading to a bigger turbo and want to know if the existing remap will suit the new turbo. I am thinking i might need a full retune as the standard injectors will max out at around 210rwkw?
I am just after a bit more power and have around $2500 to spend.
I was looking at either a gt28rs or a turbo from sliding turbos. would the 28rs be better than the hiflow? the hiflow is $980 and the gt28rs is $1400. that would leave me $1000 for injectors and a retune. Are gtr injectors getting a bit old now? I can get a set for $350.
Thankyou All
  • 8 months later...
Sorry to bring such an old thread back to life but can somebody direct me to Dr drift. Far as a contact email or something. Can't really call him course that would be expensive from where i'm calling from ( STATESIDE)....But been reading alot about Remapping lately and consider that for what i'm shooting for it is the best bang for my buck. So if one of you Aussies could be so kind and give me some kind of contact that would be very nice. Could you PM me his contact please. Thank you.
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
