On my car..(92 Skyline R32 GTST)
The stock boost gauge in the dash shows...
+7
0
-7
I've also got an Autometer boost gauge in the car..
MY question and concern is as follows..
Question.
Where does the Standard boost gauge get it's reading from?
Concern.
On full throttle in say 2nd gear at about 5500rpm the autometer gauge shows that I am hitting about 10.5 - 11psi boost.
The stockie gauge doesn't even reach the +7..
WTF??
Which one is right?
I'm not sure where the autometer gauge is connected (haven't had the car for that long and haven't spent time looking around).
The only engine mods are BOV and K&N pod filter..
Exhaust is standard.
has anyone else noticed this in there skylines?
https://www.sau.com.au/forums/topic/1180-boost-gauge-issue/
The standard gauge isn't in psi. Ignore this and work off the autometer one for psi readings. Inside the engine bay in the back drivers side corner is a small plastic box attached to the firewall with a vac line coming out. This is where the stock gauge gets its signal.
Cam
Thats a lot of boost for stock, i'd check the actuator line for chacks
https://www.sau.com.au/forums/topic/1180-boost-gauge-issue/#findComment-24208
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
