Last night i was driving home and all of the sudden when i put my foot down to rev up 3rd gear the engine started to shudder like it was about to run out of gas (the was half a tank of gas in the car). The problem continued for a little bit, i was able to drive home by keeping the rev's under 3000rpm. I rev'd out 2nd gear a few times on the way back home, and everything seemed fine.
Yesterday i took the atmo bov off and connected the standard plumback setup back on, so not sure whether that has anything to do with it.
Also on the odd occasion, when i'm driving i'll put my foot down on the gas and for a split second theres the slightest of hesitation before the engine starts to rev up. Almost like one plug is fouled up.
Any ideas of where to start?
https://www.sau.com.au/forums/topic/118020-r32-engine-problem/
The rubber hose or metal pipe?
I've only run into this problem now that i've put the standard BOV and
plumbing on the car.
What would happen if the standard BOV was to leaking under boost? (would it cause this problem)
Edited by lows_13
Mate, I had similar problems.....the car would be fine during th drive and on the odd occassion, it would shudder and would not respond to the throttle. I've got a multi display screen in car and I can see when this happens, there is no fuel injection at all! Had it checked out and it appeared that the AFM sensor had fouled up due to oil mist build up from the K&N panel filter....at least that's what I've been told...had that cleaned up and problem seem to be gone.
Yer it would come and go and then some times idle realy low to and sometimes run fine. I also thought it mite have been a miss but when i checked the plugs and coil packs thay all seemed fine. you should change your fuel filter every 60,000 any way
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
