Hi peeps,
As the title states I'm after a o2 sensor for my car... just installed a new front/dump pipe and when we went to transfer the o2 sensor, appears that the owner of the previous exhaust wasn't paying too much attention when putting o2 in - thread is now fuxored!
I know I can get the Ford EL one from Repco (what is the part number for that btw) but want to try my luck at finding one that is from Nissan.
Cheers for any advice/information/leads.
Stan
https://www.sau.com.au/forums/topic/118040-wtd-02-sensor-for-r34gtt/
Not sure if this is applicable for R34's, but I believe that the O2 sensor off a Nissan Maxima is compatible on R33's, can't see why it wouldn't fit on R34's though.
Please don't treat this as gospel though, it's just something I remember hearing a little while ago and may be worth checking out.
I know that going to Nissan will be the #1 option but I'd be dead if I'm going to pay $400+ for a o2 sensor!!!
Hell, I don't even understand why the car needs it, what is the point of measuring the o2 from the dump pipe anyways???
Bleh, wish I kept my other o2 sensor now :D
Go to Bursons and get an NGK one, cost me about $80.00, only make them to suit R33's (plugs are different).
I made an interconnecting harness.
Check out NGK on the net for part number.
  • 3 years later...
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
