R33 Gts-t Bodykits
ive been searching up on google and here for some decent looking r33 gts-t bodykits but i cant seem to find anything at all, i see the usual gtr kits rar rar rar can someone post up there kits and show (if any) web sites with some decent kits, the only decent one i found here was the m sport kit mmmm that looked nice anyways any help would be appriciated. thanks guys.
Lol you arent searchin hard enough.
Also tried gallery section?
Checked out hong-honk skyline forums for pics??
Checked out ns.com for pics??
Tried going into sponsers section n checkin out their websites?
Tried justjap also?? Check out their site.
I just googled and i found heaps!!
www.nismo.com.au
they sell mostly all type of r33 kits.. Check out the pics
try fibrecrazy.com for decent kits and even powerplay imports which stock some awesome stuff.
btw my kit is paint and got fitted this morning , so ill post pics in the VIC section 2nite
Edited by mr_crust
  • 4 weeks later...
i bought my car with the full m type kit except it came with this wierd rear bar. i was going to take it off but it grown on me. you haven't come across anything like this one by any chance..... What is it???
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
