Im in the market to buy an r33 gts-t and i want to know how much the stock bottom end can handle before it starts to shat itself. My true aim is looking about 240 - 250 rwkw, i also wanted to know what kind of modifications would i need to achieve this sort of power figure. Once again any help would be much appriciated guys. thanks.
https://www.sau.com.au/forums/topic/118069-rb25det/
As above do a search heaps of info on this topic also have a look at the website in my sig it contains a R33 GTS25T tuning guide and should answer your questions.
cheers
https://www.sau.com.au/forums/topic/118069-rb25det/#findComment-2172187
i have personally seen a 350kw stock bottom ended rb25det on ht dyno, BUT THIS DOESNT GUARENTEE RELIABILITY!!! you can have 1000 horsepower from a stock bottom end, it will last about 5 seconds, but YOU HAD IT!!! 250rwkw is very acheivable mate.. hi flow turbo injectors zorst computer etc, 240rwkw...
https://www.sau.com.au/forums/topic/118069-rb25det/#findComment-2172222
250rwkw~~
umm recomend
itercooler
ECU
boost controler
GT28? balance your power need vs turbo lag
wastegate
exhaust manifold
front pipe BMTL (I think) sells one here
exhaust Blitz type R is nice...3"
high flow cat, Magic 4"?
Pod filter Apexi, don't go for HKS mushroom
CAI box
Q45TB
Z32afm (don't remove the afm not required for this power range)
plenum? if you want to be fancy
plumb back bypass valve
fuel pump
fuel rail
injectors..not sure how many CC youll need abt 500??
more importantly paint your car red and stick more decals!!
https://www.sau.com.au/forums/topic/118069-rb25det/#findComment-2172423
