hey guys,
im thinking about going down the thermo fan path and scraping the engine fan.
im thinking of installing 2 thermos infront of the radiator and was wondering what sizes or brands will be a direct fit.
Taking off the engine fan saves a kw or two doesnt it? ive also heard that the thermos will do a much better job at cooling.
anyone got any ideas?
cheers
have you done a search, been covered alot lately (last month or so)
depends on the fans you use and the shrouding you fabricate..
if your willing to spend the time to get it right (and the money) then go for it..
hey guys,
cheers
Yeah mate, i bought some EF Falcon thermos from a wreckers for $100 and placed them in front of my radiator (R32 gtst). Make sure you reverse the direction of rotation so that they push the air thru the radiator, not suck it thru it. Also, make sure you spend heaps of time fabricating (or modifying the OE one) a shroud so that when the thermos are on, no air escapes around the radiator. I found Clark Rubber to be a cold mine of sealing rubbers! Mine work much better than i expected, they push heaps of air. Ill try to find a photo for ya.
Shaun.
Oh yeah, ive got an air diversion plate that goes over the fans, so you cant even see em! I reckon they're great.
Edited by Shaun
At the moment my r33 doesnt have a fan shroud even for the engine fan, dunno why just wasnt on the car when i bought it.
i heard that davies craig are good quality thermo fans?
i was reading up on the 2x14" vs 1 x 16" but didnt really get anything out of it.
how did you make a shroud so now air escaped around the radiator?
cheers
I just modified (extensively) the existing Falcon shroud, and made it fit to the contours of the chassis. I then put car door rubber on the edges of the plastic shroud so that no air could escape between the fans and the radiator. Its not an easy job, but the benefits are great.
Also, Original Equipment (OE) manufacturers will always make better cooling systems than aftermarket. Take note of the rake on the Davies Graig fan blades compared to the Falcon (or any other) fans. The Davies are inferior in my opinion. And its no good just bolting on a thermo with heaps of exposed radiator left around it.
Shaun.
oh ok, i dont mind spedning abit of time and money fitting it myself and modifying it but i think ill need someone to help me with the wiring as to when the fans should switch on and off.
also was it $100 for both the fans?
Shaun,
what temp based switch did you use to activate the thermos?
did you see any difference with the std shroud on v's off ?? as it would cause a restriction now that air is pushed through it rather than being pulled through it?
temp issues at idle in the city?
Suggest you leave engine fan & find yourself a shroud, nothing will cool as good as the factory setup. It is a clutch fan so it only drags with high engine bay temp. will free spin on the highway. If you insist on going to electric fans your mate is steering you in the right direction with the Falcon fans, but take note to the importance of the shroud. Bolting Davies Craig fans directly to the core is a waste of tme.
cheers
My own experience is that it's not worth an engine for the couple of kW you will release by removing the weight of the factory fan.
I found it difficult to get airflow through the radiator, so much so that even at fwy speed, a slight uphill would cause the fans to activate.
Hi All, just finish my thermo fan installation. I'm using BMW e34 fan (17") . Install direct to the oe plastic shroud with rivet & aluminium bracket. The signal from relay connect to the temp. switch that locate at the bottom of the radiator. If connect from tem. switch that locate at the intake manifold ( beside the thermal transmitter) the check light will bo ON.
Once the themp raise to the working temp. the fan will be ON aorund 5 sec only.....
Is it my connection right ? Advise please
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
