woo hoo
2 more days!!!!!!!!! :thumbsup:
although new clutch was installed - and seems its still not 100%
Im pretty p!ssed.
going back in tomorrow morning.... might have to bring the sh!tter $150 VL out !
  • Replies 132
Posted Images
Will be great.
I fabd up the camera mount.Tests for worthiness are 2moz..
Just a question...It is on the flat skid pan right...Cause when i watched an antilag vid of morgs,it looked like EC but it was more like a mini skid pan circit..
i think you are taking about the figure of 8, thats seperate from the skidpan that we will be using (unless i have missed something BIG! lol )
i have a clutch issue too, my thrust bearing has voiced itself as on the way out this last week, and i have been informed to take it easy on the clutch, convenient seeing i was looking forward to some clutch abuse on sunday!! now some of my fun is ruined :whistling:
sounds like it isnt the week for clutches :(
mines getting another look over today... *fingers crossed*
figure 8 isnt in - its very expensive :)
Ben - of course your still in mate!
Ive got an in car set up too - its a suction pad - back window and away you go!
although my vid cam is old and big and emo hahahaha
Ben,
You can have stuff in there but cause you'll be a hektik drift0r like myself :) they will be moving around and it could break (depending on what it is!)
If you need to bring stuff, theres a viewing "hut" which is under cover so you could leave it there, my mrs will be there so sh can keep an eye out, and plus we all good people!
Ive cleared everything out - last time I didnt and my tool box went everywhere in my boot :)
clutch seems fine!!!
lets just hope she's all good!!!! :)
Tosh - saw your euro there next the the dr30 sky !
Guys - thanks again for helping us make the day happen :D
Tosh - clutch was fantastic !!! :whistling:
Ben - vids would be sweet :P
Martin - good to see the change of tyres helped too :P
photos photos photos please !!!!!!!!!!!!!!!!!!!!!!!!!!!
Cheers,
Chris
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
