  • Replies 504
im not an idiot mate.. thats hurt my feelings a bit..
no need to go to name calling.. im asking for opions
i just dont see why aynone would want these things.. im keen on these hybrid cars man.. good for the environment man.. we should be loooking to do our bit for mother nature buddy.. hence.. dont hate appreciate:)
no i dont have a car of my own atm.. and what does age have to do with anything?? if i was 10 or 100 it shouldnt matter..
maturity is overrated....
"on our forum"... see thats the community spirit :D
Age does matter, because you come on here and act like a tosser, when you obviously have no idea what you are talking about. By the sound of things, you have no appreciation for cars, you probably have a family member or mate that has a Commodore which you think is the best and fastest thing on the road, but you have no idea, you need to wake up to yourself.
If you have nothing constructive to contribute to the forum, then bother someone else.
Anyway, that is my rant. If you are going to come on here and bait people into an arguement, then good for you. I have no inclination to get into an arguement with someone who has no idea about cars, and evidently has the IQ of a house brick.
You are not talking to a half-witt, trying to defend your comments by twisting the wording and making out like I misunderstood them is not going to work.
You are not asking for opinions, you are expressing an opinion, which you should have kept to yourself.
Again, it shows you have no idea about cars, talking about Hybrid cars, after you make a comment about preferring Commodores. I dare say that you have no idea how a Hybrid car works, or their impact on the environment apart from generic articles you have probably read in a 2nd-rate magazine.
Fair enough that you don't like Skylines. The people on this forum don't care that you don't like Skylines. If you don't like them, why are you here? You have probably never driven a Skyline and have no basis for comparison. I have no time or care for people who obviously just want to pick a fight, so this is Quinny signing off.
    • Haven’t had the chance to drive it yet with work being a nightmare, will definitely be doing that at some point this week. got these so that grip won’t be an issue at roll racing
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
