  • Replies 504
Not me! Didn't you know it's a fact that ugly or psycho chicks just buy Skylines (particularly R33 GTSts) as a means of attempting to attract guys?
I would have to say that I havent see a psycho or ugly chick drive a skyline yet!!!!!
They are all lush from were I have been standing so you either need you eyes checked or you are hanging out in the wrong area and dont pick on the girl!!!!!. I know my cars and I buy them because I like the power........
Posted from a female that has driven and owned a 180sx,R33 GTSt and R33GTR and I aint Ugly or Psycho ask my husband!!!!! you weak little man................ :thumbsup:
And as for this thread its STUPID I love my imports always have always will you can do so much more to an import and get massive amounts of power out of them. With a holden or ford there is only so much you can do.........
Edited by N1 R33 GTR
hahaha yeah im sorry if i offended anyone ay !! hahah it was a joke to get some old ppl to respond again !!! hahah but some of the calls in there were priceless !! hahahaha im still cracking up at the snapper call!! pricless !! hahhaha
btw hi to all the new ppl!!! no offence :D and if u are angry hey lighten up youve made alot of ppl laugh :)
omg omg paul :no:
now how did i guess it was you after reading just the first two pages...!? good to see you haven't lost your charm mate :)
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
