H Beam Vs I Beam Rods
Daves stupid question for the month,
After market rods seem to be one of 2 types, h beam or i beam, where as stock rods seem to be all I beam. Other than the obvious different appearance is there an advantage to either of the two?
Cheers
Dave
i have been told by a mechanic that the H beam are lighter than the I-beam while still remaining strong.
so are good for revvy engines.
sure there will be alot of different opinions.
Cheers
Dave
We use I beams in engines that we intend to rebuild often, they tolerate more handling and light hits. You can stuff a H beam rod with just the slightest nick. Otherwise no difference in the real world.
:ermm: cheers :)
Can you ellaborate on that one please SK?
(re: "stuff a H beam rod with just the slightest nick"
i think he means that once you nick a H beam it dramatically weakens its structure as it uses a design to be strong when complete, and the thickness of the H in the rod isn't really thick..
only analogy i can think of is an alluminum can
if your a light weight you can stand on one without it crushing, but if you tap it on its side while on it, it'll crumple real quick..
same sort of principal.
Edited by Craved
 Share
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
