I were in Brisbane tonight and just as i were about to jump back on the Gateway Motorway at about 6:30 there was a huge explosion in the sky followed by a large white green fire trail that spread about 1/3 of the the length of visible sky.
Question : WTF was it ?????????
I have witnessed a meteor shoot down to the ground in Goulburn and it was not like this
It was a definate explosion then stream of debri or something
Dan it was when i left your house so you may have seen it but im baffled and i were too slow to get the camera phone ready :D
I checked the BOM and there is nothing reported
Just wondering if anyone else saw it??????
I were in Brisbane tonight and just as i were about to jump back on the Gateway Motorway there was a huge explosion in the sky followed by a large white green fire trail that spread about 1/3 of the the length of visible sky.
Dan it was when i left your house so you may have seen it but im baffled and i were too slow to get the camera phone ready :P
Drugs are bad mmmmkay!!! :D
Seriously though that sounds pretty full on I wonder what it was!!!
It is the apocolypse for sure
it is time to repent of your sins people and get ready for the rapture ... the end is nigh
I saw the moon run red with blood two days ago and I felt earth tremors this morning!
it's all over ye sinners
hahahahahaha, suck it bitches. I saw it too. Was quite possibly the most awesome thing I've seen in my life, and you all missed out .
(yes I am for real, I really did see it.) Was like this horizontal super low flying green firework with bits of it falling off the end of the tail as it went. Very cool.)
it was more like 6:20pm IIRC.
hahahaha hi5 :sorcerer:
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
