Getting some Work VS KF's for my R32 gts-t.
Just wanting to know if these are going to fit alright with the guards flared and lipped.
The sizes are:
F 18x9 +26
R 18x10 +13
Can anyone who knows or had simular experiences help me out?
Thanks
Edited by Justin O
https://www.sau.com.au/forums/topic/118164-work-wheels-13-fit-r32-gts-t/
I ran 18x8 with 235s on the front of my 33GTSt, with +35 offset, 18x9 265s rear +35 (I think).
I reckon you'll struggle to fit the 18x9 +26 on the front unless running a narrow tyre like a 225, as they will stick out of the guards.
Similarly the 18x10 +13 is closer to GTR offset, so will definitely stick out the guards, by an inch or so...
looks like lipped and flared :ermm:
they wont fit on a 32GTST without some SERIOUS guard work. and that's at factory height. if you are lowering too then i say you will be hard pressed to fit them at all.
There on a wide body S13 atm. The front gaurds are a tiny bit wider then the 32's. Was going to take it to a hot rod shop to get flared and lipped. Herd they do it the best. My car is currently 11cm high + gonna run spacer for the fronts, so ive been told to do.
Thanks for the replys.
Edited by Justin O
yeah, you'll have guard problems
these are some 18x10 +11's on my rears (with flared guards)
(i put them on to test fit, i dont' drive it like this...)
http://i2.photobucket.com/albums/y19/merli...12/IM000091.jpg
http://i2.photobucket.com/albums/y19/merli...12/IM000081.jpg
can't remember what the fronts were, but you'll probably have similar issues...
That looks hot as mate! Shoulda left it that way!
P.S. Sorry to be off topic, but did you paint over the 4 door lights to make them look like 2 door lights? Or is it some type of plastic cover? PM me with the reply if you like I am keen to know how you did it.
that was before my respray, and previous owner had painted over 4-door tail lights. it looked really bad up close.....
http://i2.photobucket.com/albums/y19/merli...uroline/kh2.jpg
http://i2.photobucket.com/albums/y19/merli...uroline/kh1.jpg
^ those are a similar offset wheels, on the same car... (after respray)
Hey you no g-four off ns.
His old wheels, Alex has them and thought id get them.
Alex rekons spacers on the front will your fine.
These are the wheels.
Alex rekons spacers on the front will do it.
those VS-KF's that alex has require spacers to clear the brake calipers on S13's with 5stud / r33 brakes. Not sure about skylines, but probably a similar story there. If you are keen on those wheels, tell alex to test fit them on tim's car (that's me)...
They fit andrews car (g-four) fine with 20-25mm spacers i think.
So, what were the offsets for the rims on their own? and what size spacers? subtract the width of the spacers from the offset, and you have the correct offset, then use wheel/offset calculator.
damn those wheels look sick. to make them fit the key is stretched tyres and a BIT of negative camber. ive got 18"x11" (not sure on offset) with 235 tyres on my r32 gtst. believe it or not but they dont even scrub with a full car. heres a pic
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
