  • Replies 53
Yes, it fits the series 2.
Payment Instruction
Postage & Handling = Free freight Australia wide, required $40 freight insurance for possible loss or damage in transit
PAYMENT TO FLYING PERFORMANCE INTERNATIONAL PTY LTD
ST. GEORGE BANK LIMITED
BRANCH NO. 112-879
ACCOUNT NO. 065766824
PLEASE you must give the bank your forum user name as the description of the transaction. That way it shows up on our bank statement with the amount you have sent us. So we can match your order with your payment otherwise there may be a delay for us to match the payment to your order!
After you have made the payment, please you must e-mail us with your payment date & amount, your name & postal details.
Once we receive your payment, we will inform you and send it at the same time.
It will be packed and sent securely in boxes or bubble padded bags for best protection.
Hi sorry one more question
what is the different between the one you are selling here and this one:
but this one you are selling for $650.
another question.
to install the kit is cutting of the car required?
Flying Performance International is the only official online Hybrid dealer
Flying Performance International official website www.flyn.com.au
Check out the Hybrid official website at www.powerdigger.com
Now, Flying Performance brings you the best ever deal you can find in this financial year, we are offering the 100% genuine Hybrid GT Spec intercooler kits for $650 delivered.
For this group buy, full payments need to be received before 26-05-06 and delivery will be made 01-06-06.
Check out all the photos of each kit at www.powerdigger.com.
Hybrid intercooler kit $650 delivered
New s13 / 180sx sr20det
New s13 / 180sx ca18det
s14 / s14a
s15
skyline r32 rb20det
skyline r32 rb25det
skyline r33 rb25det
skyline r34 rb25det
GC8 WRX
Supra Twin Turbo
Soarer Twin Turbo
Pulsar N14 GTiR
evo 4-6.5
evo 7 & 8
*All kit contains one latest Hybrid GT SPEC Tube & Fin Intercooler, all necessary brackets, screws & nuts, silicon hoses, aluminium piping and stainless steel racing clamps
*All piping kit comes with a step-by-step pictorial instruction for easy DIY installation
* 1 year manufacturer warranty
They virtually the same, the only difference is the colour.
$650 is with the polished piping, where as the cheaper one has the red colour piping.
everything else is the same.
Got mine today thanks mate, that was fast delivery ;)
looks great
Cheers
Bizzy
Very good to hear you received the parcel, thanks for your purchase.
can you post some pics after you install the kit please?
thanks
Flying.
Latest SABER Stainless Steel Mesh Air Filter $35 each
Engine power is directly related to the airflow both coming in (Intake) and passing out (Exhaust) of the engine, factory intake systems are highly restrictive, so limiting engine power and torque. Saber Air Filter produces smoother and more even airflow with increased velocity for optimal air / fuel mixture. Installing our Saber Air Filter is one of the easiest and most inexpensive ways to increase engine response and better fuel efficiency.
* For both Turbo and NA cars
* Strong structure with 304 stainless steel mesh filter used
* 3" inlet with stainless steel racing clamp included
* Proven power gain for maximum performance
* It produces much louder intake sound and instant power gain
* Easy to maintain, fully washable & re-usable
* 2 sizes available : 16cm base width x 11.5cm height
12cm base width x 13.5cm height
can we organise pick up??? how much would it cost for pick up???
sorry, we dont do pick up anymore as we changed office location.
we just send it out after received payment.
Flying Performance International is the only official online Hybrid & SABER dealer
Check out the Hybrid & SABER official website at www.powerdigger.com
SABER 60mm ELECTRONIC GAUGES
SMOKEY LENS SERIES now for sale! $180 each gauge
SABER 60mm gauges are electronic blacked out gauges which have high responsiveness and refined designs. When the car is off they have a black face with no numbers on them. As soon as the car is turned on, the gauges light up in bright white with full effect.
* SABER electronic gauges provide more accurate reading over the mechanical type gauges, giving you a peace of mind over the reliability of your rides.
SABER full-line up: boost pressure in PSI (for turbocharged and supercharged engines), oil temperature, oil pressure, water temperature, and air / fuel ratio, all with SABER black face and white dials.
* SABER gauge dials are invisible when the ignition switch is off. Once the ignition switch is turned on, a clear display appears with white LED illumination. A red emitting instrument needle pointer are used in the gauges to increase visibility at night and in low-light conditions. They also features built-in light dimmer function.
* SABER gauge pointers are driven by stepping motor with a microprocessor, needle accuracy up to 0.1 degrees of movement. It provides a smooth instantaneous response for rapid acceleration of high performance vehicles.
* The included removable gauge visor is for eliminating the virtual image of gauges reflected on the windscreen.
* All SABER gauges are applicable only for 12V vehicles.
* Each Kit also comes with gauge mounting kit, gauge visor, all wiring and a step-by-step instructions.
hey mate
do these kits bolt str8 into place on the R34 GTT
or do you have to modify anything?
let me know
One major thing you need to do is to cut one hole for the piping to go through.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
