you can get away with using a blade to get the layer of crap off the block and head surface.
sand the block back with some sand paper (coarse-ish wet and dry will be fine).
next thing would be to check the flatness of your head with a straight edge. if it comes out straight you can just sand it back with some coarse wet and dry.
get yourself some metho and clean both surfaces with a clean rag before putting the head gasket on.
if the head doesnt come out flat, take it to a machine shop and they'll charge you around $50 for it, its worth it if you're bothered to wait a few days.. this is what my head looks like after the machining:
Why do you want to remove the cyl head? If its just to change the h/gasket just leave it as it is, if it blows then remove and replace with a metal gasket. While the head is off you may want to service it and check the block for warping as well.
Don't listen to him, If your head gasket went the first thing ill be checking to if its cracked, warped ect....
Then go from there, the last thing you want to do is change it and the same problem happens again...
I love this "While the head is off you may want to service it and check the block for warping as well"
To check the block i think you need the block out....
to check the block for cracks you'll need it out. but checking it for warping is fine while its sitting in the car.
and if he wants to swap for a metal head gasket before his current one blows then whats wrong with that?
he's probably got his reasons.
Nothing.....
If i was to do that i would do a total rebuild though .... Each to their own.
Currently running a GT30r turbo on 16psi (light tune)...
The fact I'm still running the stock gasket makes me worried, and hesitant to track the car.
I've been given conflicting information from different sources. Some say it's perfectly safe to run 16psi on a stock RB25det w/ stock gasket, others say I'm stupid and asking for trouble.
I don't know who to believe....
Wil, damaging your head gasket is only a concern if your engine is being subjected to pre-ignition/detonation when run hard for extended periods (which causes massive spikes in peak cylinder pressure, hammering the gasket).
Nissan head gaskets on RB turbo engines do their job very well. I'm assuming the gasket hasn't been fiddled with at some stage, but if your tune is spot on- then don't worry about it.
    • And 90% of the time those people turn out to be wrong anyway. But they still treat themselves as a victim...
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
