lol is there some sort of anti lag and launch control feature?
I wish..
f**k I just read it... Its madness, this guy is a god.
Do you have a link to the latest build? Save me wading through 400 posts.
And he's even considering launch control and antilag...
Edited by The Mafia
There seems to have been a slight problem with the database.
Please try again by pressing the refresh button in your browser.
An E-Mail has been dispatched to our Technical Staff, who you can also contact if the problem persists.
We apologise for any inconvenience
Hmmm.. their database looks as solid as SAU's :)
Hi ppls,
I've been following the development of FC-Tune for quite some time now.
It appears its finally on its last stages of development.
Here...
http://www.rx7club.com/showthread.php?p=5658689#post5658689
and look at this nice little piece
http://www.rx7club.com/showthread.php?t=533202
I've made sure FCTune works with the R32 RB20DET powerfc's. :thumbsup:
If those who have other power fc models which to make it work simply download 0.53 or 0.54 beta release and perform a scan with the datalogit box hooked up.
Post it to him and hopefully you should receive an email stating its all a.o.k. :)
Very Impressive
andre is busy adding features and making it work. a new version is scheduled to come out in a week 0.55 (current is 0.54). i am not sure when rb25det will be supported (or rb26). he seems more intested in honda (as he has one with him and rx7 also). so they get priority i would assume. he has also redone the interface in fc tune to be around the styles of the new office 2007 layout and pictures.
the fc tune is designed as a multi ecu tune software, he plans to support autronic and other ecu's later on.
the box/cable dongle he will be selling he plans to offer flash upgrades for it. it will work with kashima's dongle/cable and fc datalogit versions also and his own.
andre has also made some custom devices for the powerfc (and his interface) but they are coming at a later stage. he made a DIN sized head uit that controlled his stereo, powerfc map switching and some custom guage display unit.
andre has also opened up the old powerfcs (say 2.32 pfc) and 5.1 ish versions and 7.x versiosn and found that the older one's arent flashable but the newer versions are reflashsable and have an onboard connector (he believes for apexi staff and excel tuners to change custom stuff).
i have also seen/heard of people have their stock PFC sent to apexi to rechipped as PRO version, not sure who/how/$$$ on this one and if its available.
the auto tune feature sounds very cool using wideband as real time input and its just mathematics from there onwards. IGN autotune would be fantastic and certainly possible, relying on the stock knock sensors (assuming it was safe and acceptable). i mean i rely on the stock knock sensors to IGN tune so i dont see why a computer program cant
Interesting, is there any advantage to this software over the datalogit program that most poeople use.
Is datalogic as available and free?
I will be putting together a 26/30 soon and am unsure what pfc i will buy (rb20/25/26) to run it in my r32, this software looks fantastic.
Even though i have a dyno i wont be doing the tuning so would i be better off just going to a place with the datalogit and getting them to tune it.
Sorry if slightly off topic, Mick
Ive found datalogit software buggy, unreliable and generally sucky.
The interface is crap, if you load the software and hit enter with nothing else it loads a stock tune directly on your powerfc (assumiing its plugged in).
The logging is a bit strange (basic + advanced, why two??)
It certainly does function, and offer what is promiseb but IMHO its a very poor attempt and the VB code sucks, worst environment ever.
FC Tune is done in high level C so its portable between platforms and PDA's etc are supported.
You don't need FC Tune/Datalogit but the main advantages are;
Able to edit AFM ramp (useful if using Z32,Q45 and want to rescale it).
Able to save/load tunes
Can do map tracer plotting a sensor. ie: Knock Map which plots knocking values (either min,max,avg) onto a Map Tracer window so you can see what cells knock more than others
Can do tune compare between .dat files
I've done wideband tuning on the road and IGN tuning on the road without doing it via datalogit but it was easier to IGN timing adjustments with datalogit and knock map cos i could easily spot. i found it a little cumbersome using the stock map tracer and watching for engine check light to inidicate high amounts of knock. it was also much more easier when seeing areas that didnt knock much, or very low.
Fc tune is certianly the preferred and ideal one to use, I cant wait for it to be done for RB25
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
