Hey Guys,
Not sure if this is in the right area but I have a random issue with my car and no one seems to be able to isolate it? Its been to two mechanics about half a dozen times in total, we've changed a few bits and pieces but still happening! It went to one mechanic 4 times before he 'witnessed' the issue...to give an idea how random it is...
It's an R32 GTS-t manual, only mod is a muffler (came with the car). The issue I am having is really random...most of the time it runs fine...but sometimes it would stall, the idle would rise & drop all on its own or the idle would rise to about 2500rpm and stay there...it's really odd...it doesn't do it all the time or even consistently. The ONLY clue is it tends to run worse the less fuel it has - but that could just be a coincidence. I've had the car serviced with platinums to be sure...the AFM checked and recently my mechanic replaced coil pack 5 as it was 'burnt' out? - but its STILL doing it...? Any ideas?
Edited by 4doorHCR32
https://www.sau.com.au/forums/topic/118241-help-random-r32-gts-t-problem/
Hey Guys,
vacuum leak causes this, or a hold on the rubber front pipe on the turbo AFTER the afm could be leaking.. sounds exactly like the problem i had. ended up being a hole burnt thru the feed pipe to the turbo... in otherwords, the engine is getting more air than the afm is reading, running super lean, and on idle can stall, and vary revs constantly
****UPDATE****
Now we have a new element to the problem! - the car won't rev past 2500rpm...and when you press it past that point, it sounds/feels like its hitting the limiter...?? - this is particularly annoying on the freeway...as 2500 in 5th is about 75-80km...still sound like a post-AFM leak?
I'm pulling the intake out this weekend and having a good look at it, any further ideas won't hurt...
:D
Unplugg the oxygen sensor and see if it fixes the problem (leave the oxygen sensor in the dump pipe), if it fixes the problem then you have a stuffed oxygen sensor, i had a simillar prolem with my car a couple of weeks ago.Let us know if it fixes it
Edited by nizmo_freek
  • 4 weeks later...
Hey all...I checked the inlet side and everything is fine...it started to play up again so I disconnedcted the o2 sensor and it drove perfectly for about 150km but now its doing it again...??? Could this still be the o2 sensor? I might try with the multi meter...any ideas would be great...BLKGTS4R32 pm'd be as he's having the same issues!!! :O
I basically pulled the whole inlet out and checked for leaks..(as suggested above)...everything is fine...I didn't check the AFM as such...that said, I have a Q45 on the way for it...I am suspecting its the o2 sensor...but would rather be sure as I've spent 4-500 already 'chasing' this thing... :O
Also, R32 GTS-t o2 sensor can only be purchased thru Nissan I am told? $165.00 + GST...
Thanks guys - much appreciated!!!
Nismo I AM in Melbourne, I have an AFM on the way (doing a 'round of mods atm - FMIC, 2535 etc) and I am planning on getting the ECU remapped - would this help? ie if there is an issue with the ECU, will a re-map correct this? Also - and apologies for being off topic - can you suggest anyone skilled in the art of re-mapping? I want to retain the factory ecu...
RE-mapped ECU woudn't help if the ECU is dead. and "can you suggest anyone skilled in the art of re-mapping?" Nope the stuff i've heard abuot ppl in melb remapped stock ecu not good.
I think that you may have the problem that i had with my r32
Does ur cars rpm "hunt" ie. the revs go up and down when u stop or start it up ?
Does it idle at like 2000 to 2500 RPM once it stops hunting.(if it stops hunting at all)
I had this issue with my car and i tried everything to fix it but in the end it was the Cold Start Solenoid. Located just under the cross over pipe, between ur intake plume and the cam cover. It will look like a thin square "floppy disk" shaped object with two pipes going into each side of it, my guess it that it is this.
Rb motors are very prone for stuffing up this part. get a new one Not a second hand one cos you will probably have the same problem.
Hope this helps.
Thanks R32FOURDOOR (and awesome choice in vehicle might I add... :laugh: ) - I thionk I have found the solution!
BLKGTS4R32 came good with this link;
http://www.skylinesaustralia.com/forums/in...opic=113284&hl=
I've given it a shot and will be putting it all back together tomorrow for a test...fingers crossed!
:D
I had this problem that things i changed were:
AFM
TPS sensor
Adjusted idle screw
Cleaned out trottle body+butterfly
Cleaned AAC valve
Reset ecu
took air filter off(HKS TYPE)
Changed that solenoid on the aac valve(gold round thing on back of intake plume)
Changed oil
Changed coolant
cleaned everthing that i could
None of this changed my problem at all
In the end was Cold Start Sensor, im pretty sure that this is ur problem
Heres some pic of where it is.
Ps ill try and also get part no of it
  • 5 weeks later...
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
