Yeah got Hicas... I pulled the radiator out to remove the rest of my aircon. Lost a tiny bit of what looked like transmission fluid. I have one of those light test screwdriver dooba's. What next?
My Turbo timer misteriously stopped working after I took the radiator out too :thumbsup:
Unsure of what fuse to check but there are plenty of translated fuse boxs on the forum!
The turbo timer may of had a thermo switch on the radiator to only allow the turbo timer to work above a certain temp. If it did and you pulled it off or disconnected it your turbo timer won't run until it gets the signal from that thermostatic switch!
Hope it helps :wave:
