I have an R32 and have just picked up an R33 power steering pump and now have some queries. It seems that the R33 power steering belt only has three grooves (does anyone know the part number / cost for one of these bad boys?). How many grooves do the A/C and fan belt have.
Is the only difference between an R33 harmonic balancer and an R32 balancer the power steering bit?
Thanks.
https://www.sau.com.au/forums/topic/118252-belts-on-r33s/
4PK0950 - hmm.. hard to source, but must be available. I've tried 2 repcos and 2 supercheap and no luck
Here's the full table
Jan 1990 - Dec 1993, 2.0L, 6 cyl, 24V, DOHC, MPFI, HR32, GTS, EngCode: RB20E, Import
Part number Application
4PK0855 Belt Alt
3PK0855 Belt P/S
4PK0925 Belt A/C
DT19E Thermostat
DTG18 Gasket (Paper Type)
DTG45 Gasket (Rubber Type)
Jan 1990 - Dec 1993, 2.0L, 6 cyl, 24V, DOHC, MPFI, Turbo, HR32, GTS-T, EngCode: RB20DET, Import
4PK0855 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
DT19E Thermostat
Jan 1990 - Dec 1993, 2.0L, 6 cyl, 24V, DOHC, MPFI, HR32, GTS-4, EngCode: RB20E, Import
4PK0855 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
DT19E Thermostat
Aug 1991 - Aug 1993, 2.5L, 6 cyl, 24V, DOHC, MPFI, ER32, EngCode: RB25DE, Import
4PK0860 Belt Alt
3PK0850 Belt P/S
4PK0925 Belt A/C
94988 Belt Cam
DT19E Thermostat
Aug 1991 - Aug 1993, 2.5L, 6 cyl, 24V, DOHC, MPFI, KECR32, EngCode: RB25DE, Import
4PK0860 Belt Alt
4PK0950 Belt P/S
4PK0925 Belt A/C
94988 Belt Cam
DT19E Thermostat
https://www.sau.com.au/forums/topic/118252-belts-on-r33s/#findComment-2176615
