Guest gts32t
Apexi S-AFC, S-ITC and HKS SLD, will only sell as a complete package. These items are a great companion to any performance motor with the right supporting mods particularly fuel such as fuel pump and rising rate regulator.
$550
Comes with wiring harness and manuals, in perfect working order, somebody must want these. If in Sydney I can even show you how to wire them in with out ruining your factory wiring harness.
These are the 5 button type, very rare and work a 1000 times better than the old 1 button type.
https://www.sau.com.au/forums/topic/11826-apexi-s-afc-s-itc-hks-sld/
How many points does the s-itc have for setting?
How easy is it to connect without damaging the standard loom - can you give a brief description of how to connect the s-afc and s-itc please?
Yes I'm in Sydney
also are they suitable for a R33 GTST series 2 auto?
Guest gts32t
Sorry By By dont answer silly question or ridiculous offers, like $150 for S-ITC and I think I already made it very clear that I am only selling them as a package not seperately. I believe the original post also states they are the 5 point type and correct me if I am wrong is there not an attached picture, if not for everyone interested here is the picture.
:shake: :(
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
