for sale
wrecking 2 r33 gtsts and one r33 gtr.
r33gtr sump and front diff, chemically cleaned and treated, excellent cond, great for high energy sump conversion, asking $350.00
cas off rb25det series 2 asking $70.00
two sets of 380cc rb25det injectors, asking $100.00 a set
rb25det head less cams and lifters, asking $300
rb25det crank, std bearings, good cond, 34000klm, asking $100.00
power steering pump series 2 r33, asking $75.00
much much more gear for sale, pm me or reply to this topic.. thank you.
Edited by danielson
https://www.sau.com.au/forums/topic/118262-fs-cas-head-crank-ps-pump-etc/
  • 2 years later...
  • 4 weeks later...
