Ok so it didnt come with instructions and i COULD hook it up how it looks like it needs to be hooked up, but knowing my luck ill fudge it up. So any one got a link to installing a FMIC on a 32 gts-t? I remember some one had a site with a full build up of his r32 but if lost the link.
Did do a search nothing on r32 isntalls
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/118267-justjap-intercooler-install/
what do u need to know?
take off front bar.
line up piping
drill holes if neccessary
mock it up without tightining parts
confirm every piece used
tighten parts
test boost up your driveway, make sure boost holds (maybe just quickly up your street)
once no leaks are there.. throw on ur front bar
firstly this is a link for an install for a r32:
http://www.skylinesaustralia.com/forums/in...=47918&hl=*r32*.
Do you have the motorised front spolier which is attached to your front bar? You will be required to remove this to make way for the front mount intercooler. You will also need to drill a hole under the battery tray so that the piping can go through. This can be done with a 3inch or 75mm hole saw. Then you will need to mount the intercooler to the front bar reinforcement. When i did the install on my r32, you will find that you will need to cut some of the front bar out so that it sits in the front bar a little better. hipe this helps. joe
pm me if you need to ask anything else :)
ahh damnation, ran into a problem already. Removed front body kit, then the horns, now i cant figure out how to put it up. Im not struggling for width but its to long! hits the edges of some clamps which cover up some wires. Which leads me to believe im trying to mount it to high up. I need a pic of some ones install on a 32 gts-t or perhaps just some instruction on exactly where to mount it. Do i mount the top of it to the top part of the front steel bumper or the bottom of the front steel bumper. If i mount it on top part of the front steel bumper itll be about 3/4 of the way up the radiator and most of the cooler will be behind the bar. If i mount it on the bottom of the bar it will be about as high as a gutter. So id assume thats to low right?
ahh nice i was gonna mount mine on the front bar at the top.
Trying at the moment to relocate 2 little brackets on either side of the radiator which are holding electrical wires because the intercooler doesnt fit demit. Sooo cut that the intercooler doesnt fit side ways, the ad for it made it sound so easy to fit. Spewing it didnt come with any instructions either. Not sure if most people normally cut their front bar at the bottom or what but these brackets are a pain in the asssss. This thing needs to be 20 mil shorter to fit my car!! Gonna have to cut my front bar (regardless of the fact i have a type M the core seems just to big) back about an inch to move it forward around those irritating electircal-holding brackets
currently angle grinding off my front bar.. Justjap intercooler kits are not BOLT ON as advertised. You need to drill holes in just about every conceivable metal panel and hack of half your kit and bumper even with the type M. If you want a cheap intercooler thats good quality then get it. If you dont like cutting bumpers up and custom fabricating joints and brackets avoid it
Actually, they do bolt on if fitted correctly.
"Bolt on" doesnt mean that no trimming of your bar etc is required, it means they are a simple fit on the car itself.
Some Japanese kits are the same - Heck my "bolt on" Japanese Apexi Drag cooler required some significant trimming to the front bar!
Im giving up, $450 bye bye. Cut 5/6 of the bottom of the front bar off and it still doesnt fit. The core is to big to fit. Id have to cut a hole out just under neath my battery which coincides nicely with the chassis rail. Not to mention that the amount of cutting i would have to do to my front kit would leave it flapping wildly and absolutely root it. The 600X300X75 core wont fit in the space just in front of the radiator, it gets jammed about 6 inches from the top of the front bar.. I could totally cut off the bottom of my front bar but i would lose quite a bit of stabilityand would have to mount it further forward. Which would mean even more hacking of my front type-M kit.. I can see my resale value dropping every few seconds. If the core was 500X300X75 it would fit but the manufacturers decided that a 600X300X75 that would "bolt on" would be more desirable... Even though it would require major modification..
So im selling Justjap intercooler kit if any one wants it, all piping for 32 gts-t = $450.
Can any one suggest a SMIC that will give me enough flow to upgrade to a 33 turbo preferably for about $450 and definitely that wont require angle grinding huge chunks of my car away and hacking all the support off my kit..
Mate, bolt in kits, as mentioned above, are not just plug and play. No car mod is every that simple. Even installing a headunit often requires modification of the headunit bracket.
From the sounds of things, you don't have much experience with cars. I would suggest that you take it to a work shop and get them to install it.
You are astounded by the fact that "even with the type M" kit you had to hack it up. Why would the type M kit give more space to a fmic? The 32 gtst was not designed to fit a fmic. Of course it will require modification.
What it comes down to is that any mod will not be simple. I recently installed a new dump/front pipe. The bracket needed to be modified. Several things didn't line up, some flanges needed grinding etc.
Either take it to a shop, or have a decent attempt at it expecting to do some serious modding. E.g. you were having problmes with a few measly brackets to hold wires? just remove the bracket and cable tie the wires?
The intercooler that you are trying to install is not big at all. It has been fitted many times on r32s.
dude, you are going to need to drill the hole under the battery regardless (the GTR uses it stock!!)... it seems like you are trying to mount it too low if you are thinking about cutting the bottom off your bar...
The top of the cooler sits JUST under the metal piece of the front bar! a lot of people mount the top to that!!
It DOES fit!! Just sit back and think! That is the only way oyu will learn!
An r34 smic is plenty for a stock r33 turbo. But once again, it requires substantial mods to fit in an r32.
The piping faces the wrong way, and I beleive the brackets also don't line up.
The resale value on your car won't really go down by chopping the bar, because stock bars are worth nothing. I've seen them go for $20 on the forumns.
the type M bars you mean? Stock bars theres alot less of it ot f8ck up sorta. That and id have to get it resprayed. Cant believe how difficult it is to upgrade an intercooler.. I could put a fmic on a ford laser with alot less effort and cutting. SOooo angry, wanna sell car buy a barina and just forget about it
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
