ok here we go.im going to get me a stagea and have been looking at the ones with the satnav system.i know the satnav is usless here but im looking at prob replacing it with a double din setup.and looking at it in the pics posted by jspec it seems to be a standard double din size with the ac controls next to it.if this is the case i would be able to put a double din radio or a standard one and a dvd setup as well as have room for a gauge setup like andy has. so looks like i could fit 3 standard din items as well as the ac controls. well i spose ive confusled ya all now lol but im sure one of you know what i mean .
thanks all regards mike..........
https://www.sau.com.au/forums/topic/118275-ok-guys/
ah i see, as long as the climate control is not attached to the sat nav then you shouldnt have any problems...other than some tricky bracket work in there, although im sure that a car audio store could sort that out for you
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2176404
Hi
One of the stageas I have got has this instaleed ( in japan) It is a kenwood unit and fits exactly below the air con control unit in the consul. It is a radio dvd etc and also show wtaer temp etc etc dependant on how it is set up . I am not sure of the model no but these units are definately available from japan and do fit and work.I can post a close up pic anyone wants
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2176466
Hi
One of the stageas I have got has this instaled (was done in Japan) It is a kenwood unit and fits exactly below the air con control unit in the consul. It is a radio dvd etc and also show wtaer temp etc etc dependant on how it is set up . I am not sure of the model no but these units are definately available from japan and do fit and work.I can post a close up pic anyone wants
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2176472
Mike
If you buy that car or another one with Sat nav, and then decide to pull it out, I will have these bits spare.
I am only going to use the gauges in my S2.
I have also attached a picture of the rear of the Sat Nav and AC and it looks to be all one piece
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2176597
thanks guys for the info. id love to get my hands on a satnav unit tho and try to mod it so i can use the ac controls like in the pic i posted but i dont want to buy a s2 with one in it if i cant set it up like i want it i may as wel buy a s2 with the standard setup is a shame tho i recon it would look great with a afta market double din tv screen unit and the gauges plus the aircon controls on the side.would be different hey :thumbsup:
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2177535
thanks guys for the info. id love to get my hands on a satnav unit tho and try to mod it so i can use the ac controls like in the pic i posted but i dont want to buy a s2 with one in it if i cant set it up like i want it i may as wel buy a s2 with the standard setup is a shame tho i recon it would look great with a afta market double din tv screen unit and the gauges plus the aircon controls on the side.would be different hey :O
I have that set up in my S1 (must have been optioned up in a big way) and the AC controls are part of the sat nav, the biggest issue is that it is a touch screen and you contol most of the heating/cooling functions (Fan Speed) through it! I am sure you could replace it with the AC controls that are found in Stagea's without the screen but could be interesting...
I think I will try to repalce the lower Din radio part with an A/M MP3 CD tuner but will need to have an AUX input on it if I want to use the screen for anything and be able to have sound.
Screen folds forward too, there is a single disc CD player behind there!
If only it all worked here...
Let me know what you end up doing if you get one as I will be very intersted to know what can be done.
Cheers
Luke
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2179016
You could also get a single-DIN head unit with a fold-out screen, then use one DIN slot for the standard a/c and the other for gauges.
Getting a navigation device (hidden under a seat or in the boot) with AV outputs is then the next step, and you'll have the whole lot sorted without major dash surgery.
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2179957
Cheers
Luke
mm so where would i get a nav system like that here in oz
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2180023
well ive decided to get a stock series 2 with the standard double din setup and then replace it with an aftermarket tv dvd type setup.does anyone know where id get a satnav system that can be setup under the seat etc and conects to the screen in dash .???????????????????????????
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2185188
Your best bet is either to contact some of the bigger and more reputable car audio installers/suppliers or try some of the specialist electronics places like JayCar, etc.
Finding a fold-out screen is easy, and there are plenty around from Alpine, Pioneer, Kenwood, Clarion, Sony, and some of the smaller brands like NESA, etc. Then it's just a matter of finding a navigation set-up to suit.
Most of the navigation stuff here is of the stand-alone variety, like the NAVMAN, ToMTom, Garmin, etc. The one in-dash one that I can think of available here is from VDO-Dayton, but even then it would take up two DIN spaces, unless you mount the control box with the DVD or CD reader (depending on your choice) under your seats.
Alpine do have navigation stuff available, but it's o/seas only...
https://www.sau.com.au/forums/topic/118275-ok-guys/#findComment-2185550
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
