Guest INASNT
Originally posted by darkhalf
ugh... acetone was the only thing i told that might remove it. unfortunately that ddn't remove the blob dropped in the carpet
remember some time ago some product 'super glue remover' ??
if acetone works then metho should work nearly as well!
was the sperglue thing 1 of big kevs products?
The one I have here is "Magic" Brand.
It gets rid of the glue by applying it a few times and it breaks it down and you can wipe it away.
Don't know if it would leave a mark on your dash, best bet is to test it for colourfastness on a small spot of you dash which is out of view.
um.. i tried metho on mine which cleared some but not all of a mark i had on mine. I was initially worried the metho would eat away the plastic but it works a treat. I think you're stuffed as the super glue actually changes the chemical composition of the dash and bonds itself into the plastic molecules.
You could always paint it blue? hehe
Guest INASNT
Originally posted by akeenan
why did you super glue it in the first place? velcro would have been a nice idea??
coz double sided tape doesent hold hard enough
pred
the superglue just form a thin plastic layer onto on the dash. It aint that a complex thing that it changes the molecules of the dash
nah man, predator is right. Dont' get me wrong but - This is Serious!!!
The molecules on your dash may have changed forever, I suggest you immediately go and visit a Chemical Engineer or someone who is experienced in dealing with the transformations of polymers and get some help!!!!
..........or just go buy some super glue remover!
:D
hey..stop that...
seriously - the idea of superglue is to form a bond between the glue and what it bonds to. For plastic it will seep into the plastic, and that is why it is so effective at what it does. While you can try superglue remover, it will probably still leave a stain in the dash as its below the outer layer - as you will probably find out.
Originally posted by Sir R33
i was wondering if that superglue remover would remove superglue from my paint work?
Don't ask how it got there its a long story!!!
try it - it works really well (goes out and buys shares in super glue remover company)
But try it on a spot of paint you can't see first to check if it's gonna effect your paint.
inasnt - you can get some really stong double sided tape stuff, similar to the one that comes with an SAFC originally from a hardware store. It doesn't even leave a mark.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
